AEM Brake Upgrade Info From SEMA
I'm not sure if this has been discussed yet...so, sorry if this is old news. Anyhow, I spoke with a gentleman from AEM and he stated that we should expect about 2 months before they have the large AEM rotors available for our car. I saw them there on an RSX and they looked awesome! They also changed their design a little. The rotors are no longer drilled and slotted, unfortunately. They will only be offered in slotted, but still cool nonetheless. He said they update their webpage often, so just check back there periodically for updates.
-Aaron
BTW, SEMA WAS AWESOME!
-Aaron
That sounds sweet. I figure by springtime next year to add pulleys, RES, brakes and 235 tires. Now if only a bodykit wuld come out that would be a sweet ride.
Ah, if we could only shave a couple hundred pounds off of the front end we'd really have something here!
Originally posted by Crazy AcurA
Didnt someone say the new AEM brakes would cost alot? I dont know, im asking.
Jim
Originally posted by Mike
brakes are easy. rotors aren't so easy. :P
you have to pull the stock calipers to swap the pads anyway, so how much more work is it to pull the rotor at the same time? it isn't like you need a "rotor puller" or some weird-ass specialty tool.
Don't get your hopes up about them being ready within the next couple of months, that would be a pipe dream. Think more along the lines of a minimum of 6 months if ever. The brake kit hasn't even entered the development stages.
Rotor R&R is about as easy as it gets. Just make sure you've got an impact phillips screwdriver (for getting those nasty little screws out.) Not a problem on a low milage car, but the longer the road use, the more rust that gets in those little babies.
If you guys want better braking, try my setup. I think it's far better than what the car came with originally. It's not ready for the circuit, but a great street setup. Any it only cost about $110.00 retail for the pads (fronts and rears,) and an hour of your time.
I've got about 500 miles on the fronts, and 300 miles on the rears. Bedding is just about complete. Todays driving adventures in braking were, to say the least, more than adequate.
Just my .02
Jim
Just my .02
Jim
blxmjx how are you tied in with AEM?
They had a set of the RSX AEM brakes on an RSX at SEMA. They did say they're not quite ready to release them now, but will be out shortly. From what he said the rotor is the same as the CL, it's just some different brackets and such.
BoricuaTL
Apr 8, 2016 01:08 PM
Abe_Froman
Sep 16, 2015 01:27 PM
asahrts
Sep 4, 2015 05:55 PM
