Advice On Transmission Slip
Old Mar 5, 2018 | 10:50 AM
RedlineCL-S's Avatar
2001 Acura CL. Every gear drives fine except for 3rd which slips to neutral under mid-heavy acceleration (about half throttle) under easy throttle, it drives just fine. Any thoughts? It’s running OEM DW-1, changed transmission filter and cleaned solenoids. It’s like the computer is telling the car to shift into neutral. (see link for video)
Old Mar 5, 2018 | 10:56 AM
What does the CEL tell you?
Old Mar 5, 2018 | 11:01 AM
Should have probably said what that consisted of, it’s just a o2 sensor CEL. There’s no cat on the car.
Old Mar 5, 2018 | 11:07 AM
TheWeez's Avatar
I Wanna Beer
Not much to do but rebuild it. Slipping is slipping. As much as some want to think they can add some new fluid and things will be magically good again, that's simply not the case. It'll start slipping again soon enough. Time to start saving for a rebuild or 6-speed.
Old Mar 5, 2018 | 11:18 AM
Are the 194,197 miles original to that transmission?
Old Mar 5, 2018 | 12:17 PM
Knew the time had to come at some point for the transmission to start going. I’m looking to buy a 2004+ TL 6 Speed, and I do believe it’s the original transmission.
Old Mar 5, 2018 | 12:19 PM
horseshoez's Avatar
Latent car nut
You'll love the TL 6MT!
Old Mar 5, 2018 | 12:30 PM
Looking at the totality, since the beginning of 2017, of the 'thread titles' you've posted here, I think it is safe to say the 'denial' has finally left your consciousness. I don't say that to be a 'dick' and understand that you are a student with a low budget; therefore, run as fast as you can towards that '04+ TL 6 and don't look back.
Old Mar 5, 2018 | 01:30 PM
No offense buddy, but yea I’ll work towards that TL
Old Mar 5, 2018 | 11:09 PM
lateralus's Avatar
if your handy with tools and love to wrench... you can scoop up a av6 tranny and swap it..
i had a 05 tl 6 speed loved everything about that car... cept i had one of the ones with cracked dash issue..
Gray Ghost
May 1, 2007 10:59 AM
scoob5555
2G CL Transmission Recall Q & A
Jan 29, 2005 02:11 PM
rayman1031
Jul 19, 2004 12:43 AM
Y2K_TL
Feb 26, 2002 10:19 AM
