Adding tranny fluid...
Old Sep 7, 2005 | 04:34 PM
phipark's Avatar
Not Asian
I'm having problems adding some tranny fluid. I've located the bolt, but it has this metal bracket on top of it with this metal tube coming out of the bolt. I'm having a hell of a time trying to remove the bolt for the braket.
Any bright ideas?
Also, what size is the tranny fill bolt, 18mm?
Will I need a new seal washer after I open it?
It looks like I'll need an open end wrench to fit underneath the metal bracket, but I don't know because I can't get the metal bracket off.
Old Sep 7, 2005 | 07:05 PM
MiK3Y's Avatar
Any bright ideas?
theres a 14mm bolt holding a black bracket down that supports the metal tube you're talking about. take off the 14mm bolt and wiggle off the metal tube from the bolt....mine took some tugging to get off. im pretty sure that metal tube was added as part of the tranny fix/recall. once you get the tube out, you'll see the bolt already has a hole in it....no need to take it off. they probably took off the OEM fill bolt and replaced it with one with a hole on top.
Old Sep 8, 2005 | 12:15 AM
Allout's Avatar
Blown is Best
If you have the right funnel, you can also add fluid through the dipstick hole.
Old Sep 8, 2005 | 06:35 AM
louisn's Avatar
Sounds like a good $2.00 investment to avoid the all the hassle and problems that might occur to DIY mechanics like me who sometimes get frustrated by hard to reach areas and frozen bolts.
Old Sep 8, 2005 | 08:20 AM
phipark's Avatar
Not Asian
Oh yeah, good idea. I'm getting a funnel instead. I can't get enough leverage on that bolt.
Old Sep 8, 2005 | 09:56 AM
civicking's Avatar
don't add fluid through the dipstick hole, its not supposed to go through there, i don't remeber why, i think because the dipstick does not go to the same place as it would be if you used the fill hole, why do you think they made a fill hole, it cost them money to desigen it and everything, its there for a reason, also remember to check the fluid with the einge off.
Old Sep 8, 2005 | 12:44 PM
MiK3Y's Avatar
the bolt isnt very tight....all it does is hold down 2 brackets. a ratchet with an extension will do the trick.
Old Sep 8, 2005 | 01:08 PM
phipark's Avatar
Not Asian
My is pretty snug. I sprayed it with some wd-40. Over the weekend, maybe it's loosened by now.
Old Sep 8, 2005 | 11:06 PM
Allout's Avatar
Blown is Best
Why wouldn't it go to the same place? It all ends up in the bottom of the pan Plus fluid will naturally equalize if you're thinking that the dipstick sits in a separate channel - which it doesn't.
Old Sep 8, 2005 | 11:07 PM
Allout's Avatar
Blown is Best
I ended up using a 1/2" drive breaker bar to get mine to pop. Sometimes you have to lean on that thing pretty hard.
Old Sep 9, 2005 | 07:05 AM
louisn's Avatar
What is your basis for this conclusion.? seems like it all ends up in the same place.
Old Sep 9, 2005 | 07:44 AM
civicking's Avatar
first there is no pan for the trans, show me, its all a case. next my conclusion is based on this, why do they tell you do add through the add plug, if it was fine to add through the dipstick why design and machine a special area to add fluid, it cost lots of money to do that and all car companies are about profit and they will not do something unless it has to be done. if you give me a little time i will ask one of they guys that i know, he is the best trans guy in the whole state, i will have an answer for you on monday or tuesday.
Old Sep 9, 2005 | 01:13 PM
SanDogDewey's Avatar
Stick it in the dipstick hole.......ya dipstick!
Old Sep 9, 2005 | 04:25 PM
phipark's Avatar
Not Asian
I'm going to have to go with civicking on this one. It's the same reason why they tell you to fill the oil in the crank case and not the dipstick. I'll just try to apply a little more mustard.
Old Sep 9, 2005 | 10:18 PM
Allout's Avatar
Blown is Best
1) There is a pan on the tranny to start with.
2) Many cars fill through the dipstick tube.
3) Why have a fill hole? Obviously it's the best way to refill a tranny when you're putting in multiple quarts.
There are many ways to refill a tranny. Just think about a tranny flush. Do you think new fluid only goes in through the fill hole?
If you want to only do it by the book, remove the oil jet tube from the revised fill plug. Then break the fill plug loose. Pour in your desired amount of fluid and you're done.
If you can't figure this one out by yourself, take it to the dealer and pull out your wallet.
This isn't rocket science
Old Sep 10, 2005 | 08:27 AM
phipark's Avatar
Not Asian
Never said it was rocket science, so chill out. I'll figure it out, but I just wanted to get some quick suggestions first. I figure it doesn't hurt to ask.
Old Sep 10, 2005 | 11:59 AM
civicking's Avatar
first there is no trans pan show me take a pic to prove me wrong, there are 3 main parts the end cover, the trans housing and the torque converter housing. next yes many cars do fill through the dipstick but not the acura transmission. and i will find out the exact reason for the fill hole and will get back to you.
Old Sep 13, 2005 | 01:07 PM
civicking's Avatar
ok i got the answer, inside the trans there is a baffle above the differential, when you add through the fill plug the fluid first flows to the differential then it overflows the baffle and starts to fill the trans. the dipstick takes the fluid measurement from the trans side and if the trans side is full means that the differential is full. but if you add through the dipstick not enough fluid might get to the differential and it can over heat and get damaged. so that is the reason why you should add through the fill plug and not the dipstick, engineers don't waste their time/money making a fill plug for no reason like i said before.
Pham Alvan
May 18, 2021 06:48 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
