AC Problem
Old Apr 28, 2009 | 04:11 PM
yankeeman515's Avatar
2000 Acura TL NGM
AC Problem
Hey my ac is working but it is making a hissing sound. The sound cycles on and off pretty steadily any ideas?
Old Apr 28, 2009 | 04:22 PM
Beavisboots's Avatar
CL-S 6Speed is rarely in
Sounds like a low charge....
Joe
Old Apr 28, 2009 | 05:12 PM
fuzzy02CLS's Avatar
Hissing? That's normal. Happens each time the compressor cycles.
Now if the compressor is cycling non stop, fast with no long breaks in between then that's a low charge which means you have a leak.
Old Apr 28, 2009 | 05:15 PM
I assume you meant what fuzzy said. Fast on/off cycles.
Old Apr 29, 2009 | 09:05 AM
2000 Acura TL NGM
yea exactly what fuzzy said. There is barely a break inbetween no longer than 10 seconds. Any ideas on getting it fixed
Old Apr 29, 2009 | 10:24 AM
fuzzy02CLS's Avatar
Well, there's a leak somewhere. it's a pressure system. If it's low on freon , then it's leaking out. Likely a O ring from somewhere. You'll have to get it leak tested. There's a Dye that's added & will leak out from wherever the leak is & should be easy to spot.
from there fix the leak & recharge.
Old Apr 29, 2009 | 01:26 PM
2000 Acura TL NGM
Sounds good thanks for the help.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
