ABS and VSA Light On?
I have had my 2001 CL-S with Navigation for about 6 months now and it presently has 54,000 miles. The VSA started illuminating intermittently and it is now full-time with the ABS light illuminating as well. A friend is going to help me use a hand scanner to pull codes this week. It drives, shifts and brakes fine. Is this similar to a problem anyone else has had? Would you recommend going to the dealer to investigate it or using an independent shop?
I also bought a rear deck spoiler off a wrecked CL. Are there any marks on the underside of the rear deck to help determine the placement for the bolts?
Thanks for your help,
Anthony
Anthony
I had a GMC Jimmy with a bad ABS sensor which cost me $250+ to repair. Is this reasonable for the repair to the CL-S? One last question, I need another transponder key, how much will that set me back?
Some of the othe posts lead me to believe it may be the transmission, although it shifts and drives fine. I am not a mechanic by any means, it is possible it may be a failure of the trans to regulate the VSA? A mechanic friend of mine did suggest this possibility.
proffesion...axle breaker
i also have an auto, 01' cl-s with 56,000 on it , but i just replaced my tranny about 5,000 ago , it runs beautifully and shifts quick and smooth by also my vsa triangle/ lettering lights up.. not permanently but it'll stay on for a good 5-10 min or so. but when it comes on by itself and i try to light up the tires it, will bog out, as if it was on. and acura has already replaced THE FREAKIN THING ONCE!
^^^ also my ABS light doesnt stay on, but after 3 replacements of the SRS airbag light, it still wont turn off they'll fix it for bout a week then the light will come on again. i know it's off subject but just lettin my anger out >:{
Originally Posted by cwright
just had my right rear abs sensor replaced about 2months ago. abs and vsa went out after replacement. The part was about 75.00
dont worry bout the "yellow side airbag" light my it flashes when there is just something placed on the pass. seat or if whoever is sitting on that seat moves the light will turn on. thats what the dealer said its just a precaution if u have like a little child there or something it will turn on just to tell you that the person may not be in the airbags path when the airbag goes off, or they may be too light... it has like a weight limit that it reads when somebody sit in the seat and when the limit is changed to a certain min. weight, the light will come on.
>i'm no expert but thats wat i was told , so u may correct me if im wrong, i wont take it personal
05 C230K & 09 135i 6MT
The ABS light will not come on during transmission problems. The VSA triangle and light may come on, as well as the CEL, but the ABS light being on indicates something faulty in the ABS system (and therefore, the VSA).
Sounds like a sensor.
Well got my car back from the dealer yesterday. He said "I have never seen so many error codes before". You may need new ABS pump, ECM, may be a short in the wiring harness, but he said basically I do not know. 2 miles from the dealer the lights went out, now they vary in brightness, but stay on. I will either drive it as is, it drives fine or find someone who specializes in code troubleshooting or wiring?
Yea guys, when my "trannie's" went.....(all three of them in a year and a half!), my guage cluster lit up like a christmas tree (abs, exclamation point, vsa). no, for an off subject question, what is a way to get the "SRS" light off? mine has been on for sometime now! it came on after i got my car back from having my body kit put on. anyone have any ideas?
thanks
topher (TOE-FER)
thanks
topher (TOE-FER)
The dealer said the transmission recall had been performed already and it appears to work just fine. It is interesting that my friends scanner said no codes and the dealers showed numerous errors. Are the dealers scanners more sophisticated than a regular hand scanner? My friend suggests looking into the wheel sensor as some others have suggested.
My SRS light came on last week. I took my car into the dealership and the tech said that the fault code was traced to a faulty driver-side seatbelt buckle switch. When the part arrives next week, they'll replace the buckle FOC.
1/4 14.4 at 95
my vsa , engine light and my traction control light came on the other day. my friend used his scanner and it read i had a miss fire on one of my cylinders so who knows ?
Received 7,180 Likes
You need a new ABS modulator--my car is in the shop right now for this very thing. 690 for a remanufactured unit from curryacura. Email request to parts@curryacura.com it's the cheapest place to get it.
Thanks for the information. My dealer suggested I may have problems with the ECU or ABS Pump. Is the ABS Modulator the same thing as the ABS pump? I was concerned that they did not know where to start and wanted to replace parts until it went away.
Did you notice any problems with your brakes? My dealer did not seem to know where to start. I do not want to give them $960 and the problem not be fixed. Some other members had problems with wheel sensors causing the same problem. I will check that first and then move onto ABS pumps if need be. Thanks for all the continued help.
Wouldn't you know it, I was driving home last night and both lights went out and are still out? I guess I will not worry about it until they come back on and stay on, which of course they will?
I don't know if they will come back on or not. I was accelerating (mildly) out of a toll booth when mine went. All of a sudden the vsa, abs lights were on and stayed on. I also don't know if the abs pump =modulator BUT I'd hazard a yes to that question. When they go on again just go somewhere and slam on the brakes and see if you skid or the anti-lock works then you'll have your answer. You can get the part from parts@curryacura.com for 690 w/ a refundable core charge of 65 bucks when you return the old one.
Oh yeah, labor was only 168 bucks for the job.
VSA and !Triangle came on when I left work tonight, but not the ABS, I give up?
1 Post
Mine went on and off for about a month before they just came on and stayed on....I did notice that when they were on, i didnt hear the abs pump when you first start the car. But not everything works good as new
ALL SHOW AND NO GO
my VSA light use to do that like come on and off every once in a while but i never got a chance to take it to the shop and i forgot about it but recentley when i was going 140 on the freeway it came on again but when i parked the car and got back in it the nexed day it was off again so i dont know do u guys think i should take it to the shop or shall i just leave it alone ?
