ABS pump cycles TWICE, not once like it used to.
Eurotrash
Just turned 60k on my 2001 CL-S, and I noticed that my ABS pump, which used to run once when I rolled away, now runs twice: once like before as soon as I roll away, and then again several seconds later. I did a search on here and noticed that some people considered the pump cycling twice to be normal, but is it?
The ABS pump on my 90 Legend started running longer and longer until I finally had to pull the plug on it, and I was hoping to avoid that. I changed the brake fluid at 45k, so that should be OK. And NO, I'm not taking it to the dealership...
it always has
Jamus22
06-11-2023 10:08 AM
IBankMouse
06-13-2020 12:53 PM
