? about Denso plugs
? about Denso plugs
Okay any suggestions from people who have replaced the plugs in their cars? Do I have to take the strut brace off? Also correct me if I'm wrong but I don't have to gap the Denso Iridium plugs do I? I would believe they come pre-gapped. Is that a word? Any suggestions would be appreciated.
Location: Somewhere between here and there, yet neither.
Always check the gap on the plugs....never trust them!!!
2001 Cl-S Black on Black with Navigation
Black Tint all around (15%~45%)
Weapon-R Dragon Filter
Weapon-R Coil-Overs
Koni Adjustable Struts
Comptech Sway Bars
(sooner than I thought...)
Comptech Headers
<font face="Verdana, Arial" size="2">Originally posted by buddha:
Okay any suggestions from people who have replaced the plugs in their cars? Do I have to take the strut brace off? Also correct me if I'm wrong but I don't have to gap the Denso Iridium plugs do I? I would believe they come pre-gapped. Is that a word? Any suggestions would be appreciated.</font>
Weapon-R Coil-Overs
Comptech Sway Bars
Comptech Headers
<font face="Verdana, Arial" size="2">Originally posted by moomaster_99:
</font>
</font>
Man, that sucks cause those tips are like pins. In that case what's the best way to check the gaps... and don't say those cheap ass coin thing that sells for like a buck.
DO NOT GAP THESE PLUGS. YOU WILL BREAK THEM. They do not need to be gaped. And yes you have to take the strut bar off.
2001 Acura 3.2 CL Type-S
Comptech Springs
Comptech Exhaust
Denso Spark Plugs
Apexi V-AFC
AEM CAI
Comptech Springs
Comptech Exhaust
Denso Spark Plugs
Apexi V-AFC
AEM CAI
Man, that sucks cause those tips are like pins. In that case what's the best way to check the gaps... and don't say those cheap ass coin thing that sells for like a buck. </font>
They do make "gapping" tools (gap tool) that have wire like feeler gages or just exercise extreme care with a really good set of feeler gauges. If you start "thin" and be careful, you shouldn't have a problem measuring.
Do see this note on how to adjust the gap on the Denso without breaking the plug's tip:
http://www.machv.com/denirsparplu.html
<font face="Verdana, Arial" size="2">Originally posted by WebToker:
</font>
</font>
"As for setting the plug gap, always follow the vehicle manufacturer’s recommendations - unless you are installing a set of Bosch’s Platinum+4 spark plugs. These plugs are pregapped at the factory to a standard 1.6 mm gap. This is necessary to achieve maximum plug performance and longevity so don’t change the gap..."
Here is the link:
Spark Plug Technology: Preventing Misfires, Larry Carley, Underhood Service, November 2000
<font face="Verdana, Arial" size="2">Originally posted by EricL:
An excerpt from a link on plugs (including the Iridium, Platinum, and Platinum+4):
Here is the link:
</font>
Here is the link:
</font>
I warned ya...
I warned ya...</font>
I do want to emphasize that you are correct about the, "I warned ya..."
There have been a number of "knuckleheads" who have just grabbed a standard gapping tool, and snapped off the thin and brittle center electrode. The tech support at Denso said that the plugs should be gapped by bending/tapping the outer ground electrode. If the car is stock, no headers, etc, then someone should be able to just pop the factory gapped plugs in (1.1mm gap in the IK16 and IK20 series).
As long as the center electrode is gently touched, all is ok. The problem comes from people prying the gap open. Even then, that has never been the correct way to "gap" a plug.
<font face="Verdana, Arial" size="2">Originally posted by maddogtx:
buddha- are you talking about the gap between your two front teeth?
</font>
</font>
</font>
</font>
I could say something derogatory but I won't.
I think I met you at the meet, you where buddhas friend that showed up even though he didn't ;-)
</font>
</font>
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
