6000k trouble
Old Feb 15, 2004 | 07:38 PM
ktown378's Avatar
A-CL nub
6000k trouble
alright...so today coming back to austin from home (hometown) i was behind this guy and he ran over a flat tire (shredded from a blow out earlier i guess) and i didn't have time/anywhere to avoid it, so i ended up running over it and my foglight went out. so earlier i was putting my foglight back in (apparently it just was pulled out) and i turned my lights back on, and now my drivers side headlight is flickering. not even bright flickering...just flickering (very dim). any clues to what i should do? i'm gonna replace the fuse tomorrow morning and hope that works. any ideas/suggestions gentlemen? thanks in advance.
Old Feb 15, 2004 | 07:41 PM
Crazy Bimmer's Avatar
Did you check the plug behind the 6000k bulb? Maybe it came loose?
Old Feb 15, 2004 | 08:11 PM
ktown378's Avatar
A-CL nub
yeah. checked all plugs, without taking off the inverter of course. i don't know what's wrong with it :|
Old Feb 16, 2004 | 12:16 AM
NiteQwill's Avatar
Adventurist.
A flickering HID bulb generally means loss of power to the bulb, it cannot ignite properly and maintain a steady voltage. From my experience with HID components, your Ballast is damaged.
Old Feb 17, 2004 | 01:55 AM
ktown378's Avatar
A-CL nub
just an update. it was the fuse. i guess the power going through the wiring was powerful enough to jump the gap on the busted fuse and still light up. replaced it and now works just like new. thanks for all the help
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
