6 Speeds with XS Power headers???
Are these a good investment for 6 speeds? What are some of you with these and like an intake running right now? I am looking to get one real quick so i can try to have my car running at least 13.9 wit ice box, crank pulley and the header by next month. I know comptech is better, but i wanna see what these can do first.
With tires and a decent driver you should be able to run that already.
just do a search on xs in this forum and you'll get a thousand threads with good info...from what i've heard...the gains are the same as the comptech but some people claim problems with the way they are manufactured compared to the comptech...but you get what you pay for...i'm going to get a pair myself just waiting for money to be right...
one problem with the xs headers is the hardware the other is the gasket and the other which hasnt been proven yet is a leaky flex pipe. Even with these problems I would still go with the XS over comptech.
to fix problems
1. buy new harware (at most $20)
2. gaskets ( at most $25)
3. new flex pipe and welded (at most $50)
SO you buy the xs ($135 shipped) and spend extra $100. For $235 you have a set that is just as good as comptech.
If you couldnt tell this is what I am doing.
3.
to fix problems
3.
to fix problems
3.
to fix problems
3.
to fix problems
3.
to fix problems
3.
gaskets arent needed. reuse the stock manifold gaskets and the O ring gaskets that come with the kit
not all flexpipes have issues.
I have over 30k on mine now trouble free
wow 14.4, problem may be more than the worn clutch.
Originally Posted by CL-Future
Leaky flex pipe has been proven, although it's probably hit or miss with all the different XS headers out there. I patched mine up with some exhaust wrap and hose clamps. I may end up just replacing the flex pipe later on down the line. 13.9 is attainable. I ran a 14.4 and that's on a worn clutch, leaky flex pipe and a #2 cylinder misfire. I'll be going later on this summer after everything is fixed...
Originally Posted by o2cls
Investment...hardly. Comptech headers are an investment, these are less than $100 bucks. If you dont like em, cut your losses and move on.
Actually, an investment indicates that you will likely make money on the deal. Buying $1000 headers does not increase the value of your car by $1500. No matter what you put on your car it is an expense, period. Unless you have a collectable car that increases in value every year (none of ours do) then any money you pour into your car you should consider it shot out of the tailpipe. Look at all the people on this forum that have pumped $10K into their car, then they try to sell it and can barely get book value on it. If you can cut your expenses by 1/10th by buying the XS headers over the Comptech then that is managing your expenses wisely.
some people have just found that the header is a littly louder then it should be. sort of sounds like a leaky gasket.
I have had XS for a few months now. They have been great for power and gase mileage, but I have to investigate the leaking air sound. I may just get some hi temp silcon and apply to the flex pipe and see if that help. If it does I may look at just replacing the flex pipe, but overall been really happy with my $145 purchase. The gas mileage has almost paid for these headers.
14.4 with all those mods? There is a guy out here near us that was running 14.2 with just AEM intake consistant like2 years ago. I have the video if anyone wants to host it. Then there is another guy here near us that I know that was running like 14.1 with just removing his resonator, he posted it last year.
Originally Posted by mrsteve
Why do you say that? 14.4 is respectable for this car.
The difference between 14.4 and 14.2 is nothing.
And he said he had a bad clutch. That will kill your times.
I had a slipping clutch and tires on my supercharged 6-speed and I only ran 14.1 I think but with a trap speed of over 108mph.
I guess so Mr. Steve
If you go to the other thread (***XS Power Header Owner***)we are starting to diagnose the problem. I think a new multi-layer flexpipe can be welded in for around 30-40 bucks.
Originally Posted by Dirty Type-S
where can one of thes new flexpipes be purchased? how was wrapping it?
wouldnt the heat from it melt the tape?
yea im going to heat wrap mines when I get it, along with replace all the bolts it comes with so I hopefully wont have any issues.
The heat will melt the tape yes, but using exhaust wrap will work. Wrapping it was effective IMO, no more leaking sound...
I bought some wrap tonite, im going to attempt to fix it. The muffler shop said it was the flex pipe
It did bring the hiss down quite a bit but it is still present. Im going to try a new flew pipe out.
is the air swoosh sound really that annoying?
im FINALLY putting mine on today after months of procrastinating lol..
Yes, its that annoying, unless you dont mind your car souding like crap.
hey o2cls when are replacing the flexpipe if you have a shop do it can you have them tell you the pipe they used. and CLS6Speednupe I know you don't have yours installed yet So if you could get the measurments that would be awsome?
