6-Speed SCers
6-Speed SCers
And of course Ramanan...
Try a 2nd gear hard launch and tell me if you get any wheel hop or just a cloud of tire smoke.
I had to get across the street and was in 2nd and decided to see what would occur on a hard launch in 2nd. There was a ton of smoke and two long black strips left on the pavement completely even. But the nice part was that there no wheel hop at all.
I understand partially why this could occur but wanted to verify this with others to eliminate remote possibilities.
Originally posted by SLY1TYPES
but would that make your car quicker or slower 0-60
On street-tires it might be a good idea! Of course right now I don't want to try any type of 'launching'
Right now 1st gear is difficult and takes extremely delicate throttle control. You can't go anything much over 50% throttle without spinning and hopping.
If 2nd gear can be launched in, controlled and held well it should produce more repeatable times. But it might also reduce overall ETs. One shift is removed which would drop the times provided time is not lost due to the lack of gearing used (not using 1st). However, you will only accelerate as quickly as there is available traction. If 2nd is on the verge (or past it) of no grip it will accelerate as quickly as 1st has the potential too.
If some slip can be had off the line in 2nd but still controllable, I would suspect that better times could be had on street tires.
Originally posted by greenmonster
If 1st gear is almost unusable, it sounds like a supercharged 6spd might be a canidate for some gear ratio changes in the gear box
The 1st time I went to the dragstrip with my mustang I couldnt use 1st gear at all. 60's were in the 2.5 range due to crappy all season tires and a very steep 1st gear combined with steeper than stock final drive gears. I ended up launching in 2nd the majority of the da and got some pretty respectable times. If you can keep it from bogging it will probably be just as fast, if not faster than using 1st and having to pussy-foot it out of the hole.
