6 speed guys with AEM please look here
Old Aug 12, 2003 | 07:39 PM
J.T.'s 3.2CL's Avatar
Has been sold for a while
I installed my intake a few weeks ago and wanted to make sure I hooked all the hoses properly. The car runs fine I just need a little peace of mind.
The AEM directions were unclear about this hose
Is it supposed to hook to here?
More pics:
Thanks, J.T.
Old Aug 12, 2003 | 09:11 PM
PimpinCLS03's Avatar
A CL-TYPE S 6 SPEED OWNER
Looks like you did a perfect job. The directions that come with the intake aren't that great, so i feel you on that one. Anyhow, the big hose, coming off the intake to the valve cove is easy to do. The hose that you are pointing at, the one under the TB, that has Radiator fluid running through it; is disconnect from under the TB, rotated 90 degrees, and reconnected to exactly where you put it. If you removed the metal tubing connecting the old hoses, then you did a perfect job. I hope this helps.
Old Aug 13, 2003 | 11:08 AM
BrendanCL TypeS's Avatar
www.WeDontDrink.com
i cut mine and used the stock plastic piece:
Old Aug 13, 2003 | 06:09 PM
Thanks.
cycdaniel
Dec 17, 2019 10:58 AM
cm561
Jan 27, 2016 10:17 PM
drone619
Jan 26, 2016 07:09 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
Abe_Froman
Sep 16, 2015 01:27 PM
