6 Speed Fluid ?
Old Nov 22, 2002 | 08:49 AM
DHRJDMBA's Avatar
XSESIVE
6 Speed Fluid ?
Anyone change the fluid or use additives for better shifting?
Old Nov 22, 2002 | 08:53 AM
Shawn S's Avatar
Someone here put REDLINE in and it didn’t work.
They went back to stock fluid shortly thereafter.
I haven’t heard of anyone else trying.
Shawn S
PS…. Our tranny shifts like “BUTTER” why mess with it ???
Old Nov 22, 2002 | 09:06 AM
DHRJDMBA's Avatar
XSESIVE
I would hardly describe that as shifting like butter. Not trying to start a war, but I have to admit that I thought that for an Acura the thing is pretty damn stiff/notchy.
David-
Old Nov 22, 2002 | 12:07 PM
6spdmanual's Avatar
Mine shifts smooth.
Old Nov 22, 2002 | 12:12 PM
DHRJDMBA's Avatar
XSESIVE
relative to what? : )
Old Nov 22, 2002 | 01:32 PM
Shawn S's Avatar
And yours is stiff/notchy relative to what ???
Old Nov 22, 2002 | 01:35 PM
Slimey's Avatar
Where is my super sauce?
My clutch shifts like butter too. I wouldn't describe the shifting as notchy at all. It's somewhat stiffer when I've started up on a cold morning, but not really anything most people would notice. It gets back to the butter state after driving a block or so.
The stiffness when cold is no different then any other car I've had or driven. All trannys are subject to that.
I think it was Wires that changed his transmission fluid to Redline and then had more trouble shifting. From what I understand, Honda transmissions are quite particular about their transmission fluid.
Were you talking about the hydraulic clutch fluid? I've not heard of anyone changing that.
DHRJDMBA's Avatar
XSESIVE
I have driven a lot of cars as I worked at a dealer while in school. 2nd gear is real notchy and the rest of the gears are just so/so. BMW has nothing to worry about in terms of this gearbox. I had an 89 Vette which was the first year for the ZF-6 speed and that had longer throws, but much less notchy. That was why I was inquiring as to fluid changes b/c I had done that in the Vette.
Old Nov 22, 2002 | 01:37 PM
DHRJDMBA's Avatar
XSESIVE
No I was talking about changing the actual transmission fluid to somehting more slick. As I said above, 2nd gear is very notchy especially on a downshift regardless of bliping the gas or double clutching.
Old Nov 22, 2002 | 01:40 PM
scalbert's Avatar
My CL-S6 has smoother shifting and action than my wife's E46 328i. She even commented on the difference and I always thought the BMW shifted smooth.
Old Nov 22, 2002 | 01:45 PM
Slimey's Avatar
Hmm...maybe your transmission is having a problem. Most of us have been quite happy with the six speed and this is the first 'notchy' problem that I can recall.
Old Nov 22, 2002 | 01:53 PM
DHRJDMBA's Avatar
XSESIVE
Nect trip to the dealer I will have to mention it. Probably not much they can do. I think its a great car otherwise, but have been unhappy with the shift feel since the day I picked it up.
Shawn S's Avatar
Well, you’re in Florida so the “cold engine” theory doesn’t play out here.
I have been noticing my shifter getting a bit “stiff” in the morning since the weather is starting to dip into the 20’s and 30’s the last few weeks.
But like Slimey posted above, that goes away after a few minutes.
My last stick shift car before the two CL’s I’ve owned was a 91 Legend Coupe with a 5-Speed..
When I started that car after sitting in the cold for several hours I had to literary push the clutch in and “row the gears” for a minute or two before I could safely hit the road.
Shawn S
Old Nov 22, 2002 | 02:09 PM
Slimey's Avatar
Shawn S
I spent some time in Iowa with a great little turbo Subaru (a great foul weather car BTW - had 4WD with lo/hi transfer case). I parked outside and when the weather would drop below +5 F I had to do a hard bicep curl or use both hands to move through the molasses in my gear box!
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Frathora
Sep 28, 2015 11:29 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
ghuns
Sep 16, 2015 04:26 PM
Dunnik
Sep 14, 2015 02:56 AM
