6-speed engine torque damper installed
Old Feb 9, 2009 | 10:37 PM
  #201
civicdrivr's Avatar
Thats ironic that this was updated today. I was out there earlier tightening everything up. The rear was completely disassembled.
Old Feb 10, 2009 | 03:37 AM
  #202
jl03CLS's Avatar
6speed
yeah i was surprised to find my damper missing...probably going to have to put the stock unit back in :\
Old Feb 10, 2009 | 09:16 AM
  #203
SlickShiftNall6's Avatar
Quarantuning
Damn I haven't checked them out since I installed them last summer. Going to check on them today. Will report back.
Old Feb 11, 2009 | 12:50 PM
  #204
civicdrivr's Avatar
Wait. It was completely gone? WTF?
Old Feb 11, 2009 | 07:58 PM
  #205
jl03CLS's Avatar
6speed
yeah it was completely gone. only thing i can think of was i didnt tighten the bolt on the bottom bracket tight enough cause that part and the damper itself were gone when i checked. the top bolt and bushings were all still there though. im surprised i didnt hear it fall out or something. sucks...those things arent exactly cheap either.
Old Apr 23, 2010 | 08:21 AM
  #206
brian6speed's Avatar
Lone Wolf
I am gonna try to attempt to install the front one. Anyone got any info on removing the stock one. Do you just remove the top part and the bottom screw or do you have to remove the mounting bracket also. I have been turning the top part to try and unscrew but thats getting nowhere.
Old Apr 23, 2010 | 08:44 AM
  #207
Quarantuning
You don't have to remove the bracket. I know that for sure. I remember clamping a vice grip somewhere below the top of the bracket. Then the bolt on top was able to back out. I'll be in my garage today I still have the oem dampers I'll take a look for you.
Old Apr 23, 2010 | 11:25 AM
  #208
rondog's Avatar
Former Sponsor
I already have one from when I first bought my blower. Anybody in the tristate wanna help me install them? So the blower has to be taken out to install one of them?
Old Apr 23, 2010 | 11:54 AM
  #209
CL-Future's Avatar
Lives in Boost
x2. Just use a vice grip or wrench to grab onto the nut underneath the bracket while you turn it with the socket.
Blower would have to be removed for the front one, unless you have some small hands or can get to it from the bottom somehow. Haven't tried the rear one but I dont think you need to remove the blower for it.
Old Apr 23, 2010 | 12:11 PM
  #210
Lone Wolf
thnx for the reply guys that was what i was thinking.
Old Jun 3, 2010 | 12:54 AM
  #211
JDTL-S2002's Avatar
anyone know how to make this work on a 2G TL-S Auto?
Old Jun 3, 2010 | 04:54 AM
  #212
Rajca's Avatar
wham bam thank you ma'am
u need to fab up some brackets bc u dont have a factory damper or any holes to mount it too.
Old Jun 3, 2010 | 11:33 AM
  #213
phee's Avatar
I got the Shifts
not true. i got it to work on my swap and i used the brackets that came with the kit. 94 teggy
Old Jun 3, 2010 | 12:05 PM
  #214
Rajca's Avatar
Pic of where u mounted it?
Old Jan 31, 2011 | 11:01 PM
  #215
ivan06106's Avatar
what's the part # lmk i want to do this mod to my car
Old Feb 2, 2011 | 12:10 AM
  #216
3.2VtecTL's Avatar
Exclamation
Im considering replacing both front and rear dampers, Since I've bought my car i've always had a severe vibration issue from the engine...Took it to Crown Acura (Richmond, VA), and they couldn't give me a definite answer that the engine mounts were bad, they dont appear to be leaking..
However I can physically move the rear shock mount from left to right, and have attempted to tighten it....Im praying that replacing both with aftermarket NRG dampers will resolve the vibration, sometimes when im in first gear the engine is shaking so much, it will pop out of gear! I would assume becasue the engine has so much movement.
I truly hope I dont have to replace any motor mounts, but I do have 190k on my CLS6 and Not positive if they've ever been replaced
Any input is appreciated!
Old Feb 2, 2011 | 01:13 AM
  #217
3.2VtecTL's Avatar
Originally Posted by Allout
Have you tried:
http://www.weaksauceparts.com/store/...p?cat=311&js=n
Looks horsepowerfreaks pulled their page but it still shows the item available through Amazon:
http://www.amazon.com/exec/obidos/tg...EBP1B&v=glance
weaksauceparts.com seems to have gone out of business?
amazon link to horsepowerfreaks its unavailable...
What are the part numbers, it seems that the brackets aren't even used. however its good to know if I dont like them, i'd be able to install on my 96 civic I guess
Old Feb 2, 2011 | 02:44 AM
  #218
3.2VtecTL's Avatar
http://www.energysuspension.com/asse...on-catalog.pdf
I was browsing through the energy suspension pdf above, and on page 11, the bushing at the bottom right, part #9.9148 red in color seems it could replace the original bushings, it also appears to be flat instead of rounded top like the black bushing to the left of it....Im afraid my oem bushings may be so damaged I wouldn't be able to resuse them...
Opinions and thoughts...
By the way WeakSOS must have clicked a bad link or site was down
Their price for the civic's damper is $79.99 plus shipping I guess
http://www.weaksauceparts.com/store/...at=1738&page=1
so the 92-95 civic is the best for our CLs?
Old Feb 2, 2011 | 01:20 PM
  #219
civicdrivr's Avatar
92-95 Civic is what Im running. Part number NRG-EDA-101.
I got mine from RobearRacing but the prices went up. I paid $63 each, its now listed at $85.
If the vibrations are that bad, your mounts are bad. Ive gone through 2 sets of mounts already, and the last set was poly-filled.
PS - Crown Acura sucks.
Tip for those that have issues with the damper staying tight - use some teflon tape on all the bolts. Mine have been like that for nearly 2 years and havent budged since.
Old Feb 2, 2011 | 09:29 PM
  #220
3.2VtecTL's Avatar
Tell me about it, once I solve the issue myself, I'll go back and explain to them what the issue was....I know for a fact they probably didn't even look at it...I basically paid 70 dollars for nothing, the service advisor basically repeated everything I stated to him initially!!
LoL they even had a sign up stating every car in for service receives a free car wash....lol my car was filthy
So once the service advisor gave me my keys, I went outside walked up to another Anthricite metallic cl, I was like well at least it looks better...tried to open the car...wouldn't open, looked inside and it was a damn auto....
Had to go back inside the dealership and wait another 20 minutes for them to locate my car, they pulled it up, and it was still filthy....I thought to myself what a waste of money and time!!!!
Old Feb 3, 2011 | 12:52 PM
  #221
ivan06106's Avatar
thanks for the part # im bout to order mines right know...does anyone know the part # for the extra bushings
Old Feb 3, 2011 | 02:03 PM
  #222
phee's Avatar
I got the Shifts
mine is completely gone as well.
Old Feb 3, 2011 | 07:12 PM
  #223
Quarantuning
^ How the hell are all you guys losing your dampers? They just magically disappeared. lol I bolted mine on like 2 years ago and haven't thought about it since. Like Civic recommended teflon tape can't hurt, but I didn't use any and I still have both dampers in place.
Ivan- you don't need any extra bushings, if I remember correctly they came with 2 sets already. Red and black, don't recall which color were the stiffer ones. You will need to pick up 2 bolts and a bunch of washers so that the bottom heim joint doesn't move around too much. There's a pic in this thread with a perfect look at what I'm saying
edit: pic is on page 3 post #105.
p.s. that kid nupe...lol what a douche
Old Feb 8, 2011 | 10:14 AM
  #224
rondog's Avatar
Former Sponsor
guess what, my motor mounts are going bad I think, there's a noise that sounds like it from the engine bay. I'm going to have my mechanic check it out. In the meantime, what are my options? Anybody making the poly filled mounts?
Old Feb 8, 2011 | 01:47 PM
  #225
civicdrivr's Avatar
As of now, no. Unless you want to go with Innovative (I highly suggest you dont).
Old Feb 8, 2011 | 03:59 PM
  #226
Lone Wolf
I would say best bet is to buy new oem ones and poly fill. Other options are keep replacing with oem or wait for a company to make them which might never happen. You could lend your car to a shop and have them use it as a test fab vehicle for custom mounts.
Old Feb 8, 2011 | 05:47 PM
  #227
StreetKA's Avatar
i just got stiffy all oem mounts only tranny mounts i am missing... i got poly... lets do it
Old Feb 19, 2011 | 12:45 PM
  #228
distortedolskool's Avatar
they are losing them because of the constant vibrations from the engine. simple solution.
loctite.
Old Feb 19, 2011 | 12:56 PM
  #229
Quarantuning
loctite.
Another good idea for anyone considering using these nrg dampers.
However now we have new motor mounts coming to market, which means to install them the dampers have to be loosened. Just went through this last week. Probably don't want them installed in a permanent fashion until the new motor mounts are installed. Just my for anyone interested in doing both mods.
And distorted, where you been? Sold your car? Really liked your posts and diy's.
Old Feb 19, 2011 | 12:59 PM
  #230
friesm2000's Avatar
B A N N E D
loctite.
nyloc nuts will do the same thing (maybe even lock washers might do the trick also)
but yes loctite is the easiest/cheapest method though
Old Jun 20, 2011 | 09:47 AM
  #231
AARONSredTYPE-S's Avatar
looks like an easy mod that is needed and helps with putting the power to the ground, looks like i will be doing this soon too....
Old Jun 20, 2011 | 10:42 AM
  #232
oh, so as far as brands?:
-NRG $99
-Spoon $109
-Ingalls stiffy $149
-Godspeed $49
-Universal $49
-Weapon-R $179
Old Jun 20, 2011 | 03:22 PM
  #233
print this out. basically you need the bolt and the 2 nuts. everything else is included.
i have not had any trouble with mine coming loose. this alone did not cure wheel hop at all. and i don't see how filling the mounts will increase the ride smoothness..??
nice.....
well, most on here have the NRG and get vibrations, i wonder if the ingalls stiffy does the same thing since they are adjustable?
oh, and the rear alone is what helps, not the front correct?
Old Jun 20, 2011 | 04:13 PM
  #234
2Fast4you's Avatar
Originally Posted by AARONSredTYPE-S
nice.....
at first i just did the front one and thought that one made the most difference then did the rear just so i would have both but after i did them i had no wheel hop.
Old Jun 20, 2011 | 09:06 PM
  #235
cool, but what brand did you get?
im really considering the spoon or ingalls stiffy mount
Old Jun 20, 2011 | 09:32 PM
  #236
2Fast4you's Avatar
I got the NRG ones off ebay but when i bought them they were only 70 a piece the thing is with these you have to do alot of playing around to get them to fit just right and they will come loose so you gotta watch them and tighten everything back so you dont have them fall out like some people haha
Old Jun 20, 2011 | 09:37 PM
  #237
wow, well, if its a half ass install, then i dont wanna do it.
plus, everyone is replacing the stock dampers, arent these supposed to be an addition to the stock ones? i see them installed where the strut tower is at on some vehicles, which is an addition to the stock dampers, so whats up with that i wonder?
Old Jun 20, 2011 | 09:41 PM
  #238
2Fast4you's Avatar
the ones they are talking about in this thread replace the stock ones the ingalls that had a group buy for is the one that mounts on the strut tower. It basically upgrading the stock ones to a lot stiffer ones.
Old Jun 20, 2011 | 09:45 PM
  #239
well, maybe ill buy the kit that goes on the strut tower and will have more luck with that. i wonder if it would still be for the 95 civic though like these are?
thanks for your replies btw
Old Jun 20, 2011 | 09:52 PM
  #240
2Fast4you's Avatar
np man glad i could help and btw i have all three of the dampeners and still have wheel hop but not much i think the last step to eliminate wheel hop is to get the poly mounts.
