6 speed ecu
Old Apr 30, 2008 | 05:35 AM
victorvu's Avatar
6 speed ecu
I'm in need of an ecu maybe. Well what happened was, i was hooking up an amp to my car and when i went to go start the car, there was no fuel coming to the front and the fuel pump wasnt pumping. I checked every single fuse, and relay. Cranks but doesnt start. I looked at where the old owner tapped the remote line and its tapped into the fan relay. I checked it using a test probe, and putting + power to the line. Last resort is to swap ecu's and reprogram. I'm thinking this because everything powers up. I even check all the grounds and everything and its all good. I use my probe to test my fuel pump and the pump, pumps. So i know for sure its not the fuel pump. So ill be towing my car to a master mechanic tomorrow. Just wanted to see if anyone had a similar problem.
Old Apr 30, 2008 | 08:29 AM
fuzzy02CLS's Avatar
You may have blew the immobilizer unit. A new ECU isn't going to fix that.
You may have shorted it out. Always disconnect the battery 1st.
Old Apr 30, 2008 | 03:17 PM
victorvu's Avatar
yea. how much do you think the immobilizer unit cost? btw how would i check to see if i messed up the immobilizer?
TypeS860
Jan 10, 2026 11:11 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
