6 speed ecu
6 speed ecu
I'm in need of an ecu maybe. Well what happened was, i was hooking up an amp to my car and when i went to go start the car, there was no fuel coming to the front and the fuel pump wasnt pumping. I checked every single fuse, and relay. Cranks but doesnt start. I looked at where the old owner tapped the remote line and its tapped into the fan relay. I checked it using a test probe, and putting + power to the line. Last resort is to swap ecu's and reprogram. I'm thinking this because everything powers up. I even check all the grounds and everything and its all good. I use my probe to test my fuel pump and the pump, pumps. So i know for sure its not the fuel pump. So ill be towing my car to a master mechanic tomorrow. Just wanted to see if anyone had a similar problem.
