5W-30 oil ok ?
5W-30 oil ok ?
I had my oil changed yesterday and after they drained it they realized they did not have any 5W-20 so they used 5W-30 (This is Mobil 1 BTW). Will this have any negative effects ?
I didn't look at the manual, the guy doing the oil change said it is supposed to use 5W-20 and he was out of it....I guess I shouldn't trust the oil change guy huh
Originally posted by macon:
<STRONG>I thought the manual said 10W 30.</STRONG>
Cost Drivers!!!!
You people are insane.....5w30 is wayyyyy to thin for the environments that you live. It should only be used in environments that are cold all the time. Mobil-1 synthetic or 10w30 should be the only thing that goes into your engines.
Cost Drivers!!!!
http://www.mobil1.com/index.jsp
yeah, 5w30 is too thin for hot temps. Basically, if live in a hot environment like miami or arizona you should use something with a 15w. If you go with synthetic you'll be cover year round. Oil flush is good when you're switching.
[ 08-02-2001: Message edited by: Zapata ]
IBankMouse
06-13-2020 12:53 PM
