4th Gen IM install questions
I Drive Like A Dick 8≈
Hey guys, I'm almost done my install on this piece but I have a couple questions to make sure it works properly.
I can't quite figure out where all the vacum lines go, I know 2 of them go into the manifold but I can't figure out what to do with the rest of them.
Thats all I can think of at the moment, any advice is appreciated and pictures always make it easier!
Whats up with RDX owners?
There are two smaller lines, T them together and route them to the port on the rear of the manifold.
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/diy-2009-tl-sh-awd-intake-manifold-install-01-cls-747771/
Ok I think I have all the hoses hooked up correctly and I did the idle relearn procedure but I still have an idle fluctuation from 2800 rpm to 1000 rpm. I took some pictures and a video.
http://i885.photobucket.com/albums/a...7/2c90a039.mp4
Check for a vacuum leak. Spray some throttle body cleaner around the lower runners as well. I cracked mine somehow and thats what led to my idle issues after this swap.
Arrrgg I can't find any cracks at all but it's still revving up to 3000. This is becoming super frustrating.
Gains for this mod are claimed to be about 15whp over stock
Idle calmed down to a rough 1500 and I threw a p0505 idle air control system. Also when I rev it responds quickly but there is about a 1.5 second delay after I let off the gas for the Rpms to decrease
Same code I was getting. I went through 3-4 IACVs before I said fuck it and blocked it off. Then when I was going to the big TB, thats when we noticed the crack.
Did you reuse any gaskets or get all new ones?
Did you inspect that gasket? Even though its metal, if it gets a crease its done.
SPRAY carb cleaner at the gasket areas (lower, tb, im sensors) WHILE the car is running. See if you get the idle to change. If so you have a vacuum leak.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
