43 offset good for our CL-S??
1-2-3-4-5-6-speeeeeed!!!!
Guys, I am looking at a set of rims 17x7 with 43 offset, question:
I have a Comptech spring drop, will the 43 offset be a concern???
you'll be fine imo.
i have 18x7 +42 and i rub a little in the back, but i'm dropped 3" on coilovers.
Originally posted by mattg
you'll be fine imo.
you'll be fine imo.
Community Architect
robb m.
robb m.
43 will not fit!
Originally posted by slyraskal
i spoke with a rep from Volk Racing and he has said that the +45 is the best offset for our car and that was for a set of 19x8 wheels
With or without a drop? If with a drop, how low?
Originally posted by Astroboy
43 will not fit!
43 will not fit!
+43, 7" wide will fit just fine. i doubt it will rub at all w/ a comptech drop.
that info was based on a drop of about 2.5" at the time i had a set of ZEAL Function B6 Coilovers
The general range is: +48 to +52
Lowering, tire make, manual, and other factors (custom suspension) will impact this number.
YMMV
Originally posted by rondog
won't rub, I have 18x7.5 and 19x8 both with a 43 offset, but the tires may make the difference. by the way, didn't you get the enkei's and why 17"?
'Big Daddy Diggler'
Rondog, what are you talking about, you rub every once in a while in the rear, ive been there once or twice when you had the 18's also. Dont forget Classy's suspension sits lower than yours for some reason. Classy no matter which way you slice it, you will rub every once in a while. That offset is way too low. SlyTls has 18x7.5 with a 43 offset and 225 40 tires and he rubbed like a bitch on a comptech drop. You may not rub every day, but i will cut my sack off if you dont rub every once in a while.
'Big Daddy Diggler'
I'm just looking out. I hate rubbing, i wouldnt wish the fear and terror that i have experienced with rubbing. If you are going 17's, there are many more options for dirt cheap at the right offset.
I had 42 offset.....for 1 week The tire store had to special order me a set of 50 offset and no problems ever. Plus the 42 offset make the car look ricey. The whells stick out too far..
yeah thanks for all the info guys I decided not to purchase this set, dont want to risk doing any damage of any sort to my car!
thanks once again!!
thanks once again!!
nuldabz
09-03-2015 05:49 PM
