375HP CLS Engine? check here....
http://www.vtec.net/forums/one-messa...age%5fid=58636
Do not know if that is possible... but, CLS cam are mild?
Who is gona do it...?
I agree with Pappy.. eventhough our CLS is only entry level luxo coupe, but to do an all motor setup for our car is just not worth it. IMO, it's one thing to all bolt-on's to give our car a bit more punch, but it's another thing to put a "full blown" race engine in it. I had an integ that I went all motor with, it wasn't anything too special, but it was running mid 13's. However, it definitely was not a nice smooth ride anymore..
Plus, since I have an auto.. I guess this wouldn't even apply to me I guess... :thinking:
The most thing I love about my CLS... is its character...
Driving around it is just like any other Luxo GT... millow and luxorious... like a persion cat ... However, once pushed ( ehm pissed) it roars like a Siberian tiger...
Originally posted by Pappy
Could you live with a rough-running higher lift cam. Not me.
It sounds possable. Look at it this way: Stock 3.2= 260hp. Upgrade to a 3.5L and you should be at least to 270hp. pocket port, up the valve size, bowl blend and other head stuff and you should be to 290hp or so. Add better cams and you could easly hit the 315hp mark. Upping the comression to 11.5:1 is a little optimistic for me, but 11:1 should be possable. Now add on some large tube headers with 2.25" collectors, merged into a single 2.5" mid pipe, with dual 2.25 or a single 2.5" exaust out back and you should have 330hp.
could also bore out the throttle body, have some custom titanium springs, raise the redline up a lil more.
Bored&stroke do you think doing a 2.5" exhaust would make the car have a lot of backpressure?
2.5" create a lot of backpressure? No I dont think so. In a stock car I actually think it might be too much. But for a 3.5L motor it should be good. Then again Im going on accord stock pipe sizes [2" duals, 2 1/4" mid pipe] because nobody seems to know what stock type-S's run
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
HeloDown
Sep 8, 2015 06:51 PM
