30k service...
Old Aug 1, 2002 | 01:36 AM
rabs99's Avatar
My Avator
30k service...
hey guys,
just got this reply from the dealer about my service cost. does it sound right?
The 30k service depending on which Acura you have will range from $324.95 to $369.95 depending on your model of vehicle. The brake shimmy that you are having may or may not be covered under warranty. Some Acuras do have a Service BUlletin relating to warped roters however it depends on make and model of the vehicle, if brake pads have been replaced and what the current percentage is. We would be able to determine this for you. In most cases the resurfacing of rotors would be covered however brake pad replacement would would be your cose at $109.95. If you have any questions please contact me at...
Old Aug 1, 2002 | 07:01 AM
russianDude's Avatar
Re: 30k service...
Originally posted by rabs99
hey guys,
Just had my rotors re-surfaced and brake pads replaced under warranty. Dealer did not even check if they really need replacement, as soon as I mentioned about brake problems they imiadeatly suggested resurfacing and giving new pads.
I think 30K service is the one you should do, I skiped all other *recommended* services, i only was doing tire rotations, oil change, and tranny flush. But at 30 will do complete checkup....
I would go with whatever dealer suggests for 30K checkup EXCEPT:
Radiator flush and changing brake fluid, those things can be done at 45K miles. this will save you another 100$.
Thuneau
Oct 3, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Hines57
Sep 24, 2015 01:58 PM
atsx1313
Sep 22, 2015 09:04 PM
