3.5l upgrade
well, there is nothing out yet. One of our board members, DeanblackCLS is working on completing the kit at his shop... but it's not quite done yet. Hopefully this fall we'll see something....
Cost hasn't been released yet either... but I'm guessing it will probably be around $2500 (+/- $500) or so plus install costs....
Originally posted by Zapata
seems like a great alternative to the S/C.
Is it only 100lbs?
I guess then it's not so bad.
But even then, since my other car is an A4, I'd say that the TLS/CLS need better handling more than they need more power.
I guess it comes down to driving priorities :-)
Nose heavy? Yea by 2.145 lbs. .
Here:
CLS MDX
Pistons 12.28 Oz Alum Alloy 12.0 Oz Aliuminium Alloy
x6 73.68 Oz x6 72.0 Oz
Connecting
Rods 1.17 Lbs Carbon Steel 1.14 Lbs Forged Alloy
18.72 Oz 18.24 Oz
x6 112.32 Oz x6 109.44 Oz
Crankshaft
41.67 Lbs Carbon Steel 44.1 Lbs Carbon Steel
666.72 Oz 705.6 Oz
Total 852.72 Oz Total 887.04 Oz
53.295 Lbs 55.44 Lbs
Juker008
Here:
CLS MDX
Connecting
18.72 Oz 18.24 Oz
Crankshaft
666.72 Oz 705.6 Oz
Juker008
hmmm more power and more torque at 1/2 the cost of the sc sounds good.. slap a sc on that sucker and whoa!
how much more hp and torque exactly are we talking about
hemants,
The blocks are identical....its the rotating assembly that is different.
If you just swap the bocks over with your stock Cl/TL-S heads, the compression ratio will go up to 10.8:1--really good for all motor and will definately make more torque everywhere.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
The one we have built has forged pistons (10.2:1), shot peaned rods and a completely balanced rotating assembly....It was built to handle just about anything we want to throw at it.....S/C, nitrous, etc.
Dean
Dean
this will void the warranty definetly right? what if i took it to the dealership to do or if i get it done at an independent shop. Would the dealership be able to tell the difference when i take it in for say my free oil changes or 7.5k maintenance service?
my dealer put mine in and ...you dont even have to change the block (not that they could tell you did) a small engraved j35a instead of j32a they'd have to be looking for it...you could just change the bottom end and noone would ever know
Cost Drivers!!!!
Originally posted by ModAddict
You mean a great addition to the S/C, right?
typeR, so you've had this done? I've noticed the "3.5 liters of fury..." in your tag before...could you give us some details? how diff was what u did to what dean's doing?
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
I called Rick Case a couple weeks ago and they told me they had lots of problems with the 3.5L upgrade they did. But typeR you haven't mentioned any problems, so what's the deal with that other upgraded CL/TL? I'm still excited as sh!t though. So what are we looking at about 15-30 whp?
Guys... I am sorry, but 300cc is not going to give you 20-40whp. I am not dogging on TypeR here... he has built a good car and it runs great. However... the before/after dyno's also included the addition of the Comptech Headers.
i've had no problems...i do consume alittle oil about 2 qt's in 6 months ...however i do go WOT alot all the way to 7200...the car rides and drives perfect ,idles perfect ...except for the power i'd say that none would have any idea it was done,the exhaust note is alittle deeper but not louder,however the details i dont know...this was a fully assembled kit.i know it's an oddessey ,block and crank but what rods and pistons is unclear also im told a better oil pump
now if someone would like to provide me with 5 megs of hosting i'd love to share a video of the exhaust note along with the streetability of this vehical and show siggy why he should have never got burnout of the month...
Censored User
Censored User
Originally posted by typeR
the only thing i can say is...im about .5 second faster than the fastest auto same setup
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
Assuming its reasonably priced!!!!
Censored User
if I understand correctly, the Odyssey engine gets only 240 lbs torque, whereas the MDX engine gets 250. But both engines have a lower compression than the type S engine. So which would be better - An engine swap or parts swap?
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
