3.5 convert Guru's, Chime in...
Old Dec 4, 2008 | 08:13 PM
artbran's Avatar
666 Speed
I have access to all the engine internals from a 2003 MDX.
From what I remember, the crank will work for a 3.5 conversion.
However, will the rods work for a 3.5 conversion?
I know that the pistons will not as the groves for the valves are too small.
Old Dec 4, 2008 | 08:51 PM
gnuts's Avatar
3.5 psi
Option 1
With '01-02 complete MDX block or '02-04 Odyssey complete block (crank/rods/pistons) it is required to purchase 2005 Acura RL pistons (new set $50 each) This is a best option still since these pistons have clearance for large 36mm J32A2 (intake) valves thus no modification needed. Despite the fact they have higher 11.0:1 CR still even supercharger can be used here with low boost up to 7psi intercooled (assuming safe AFR). In addition, if 11:1 CR is too high for you, you can use '03 CL-S pistons with 10.5:1 CR.
Option 2
'01-03 J32A2 block (CL-S)
Required to purchase the following:
-= hondaautomotiveparts.com =-
'02-'04 Odyssey (crankshaft)
Product No. 368270 or
Honda part #13310-PGK-A00
'02-'04 Odyssey (connecting rod)
Product No. 368269 or
Honda part #13210-PGK-A00
Main bearings + rod bearings
-= acuraautomotiveparts.org =-
'03 CL-S (pistons) - 10.5:1 CR or
'05 RL (pistons) - 11.0:1 CR
pistons rings (per chosen model)
Old Dec 4, 2008 | 08:53 PM
Allout's Avatar
Blown is Best
The MDX rods will work.
Old Dec 4, 2008 | 08:54 PM
artbran's Avatar
666 Speed
I was looking for this info for a while now.. Still looking for the thread thats out of..
what about the crank? will that fit or no?
In either case, I think I can use my CLS pistons and get away with it..
Old Dec 4, 2008 | 08:58 PM
gnuts's Avatar
3.5 psi
https://acurazine.com/forums/2g-cl-2001-2003-50/3-5-l-information-689568/
There's the other two threads in the 2nd Generation information thread too. (TypeR and CleanCL)
Old Dec 4, 2008 | 09:01 PM
gnuts's Avatar
3.5 psi
You can use CL-S pistons, but you'll get more power out of 05 RL pistons & rings.
Old Dec 4, 2008 | 09:02 PM
artbran's Avatar
666 Speed
nevermind about the crank.. looks like I'm looking for a different crank
Old Dec 4, 2008 | 10:05 PM
CLS6SpeedNupe's Avatar
This has not been proven, just for the record. Everyone has just been assuming that the 11.0 CR from RL pistons would equal more power when if you do the math you will see that CLS pistons with the MDX crank and rods will yield higher CR but more than likely too high for pump gas. Just wanted to put that out there.
Old Dec 4, 2008 | 11:24 PM
Allout's Avatar
Blown is Best
Here are some old discussions that may help.
https://acurazine.com/forums/showthr...hlight=thinjim
Old Dec 5, 2008 | 08:16 AM
CleanCL's Avatar
you sure it's 02-04 MDX? i think it's 01-02 MDX only. i should know.
Old Dec 5, 2008 | 01:07 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
01-02 MDX
02-04 Odyssey
As for the discussion on compression ratios using RL pistons will obviously give you a 11.0:1 CR that does not need to take into account the longer stroke. As for the CLS pistons being reused, I am curious as to what the CR could be.
One would assume that it would naturally go up for the longer stroke bringing the piston face closer to the head decreasing the final volume and thus the displacement and uncompressed volume values are changed. If we had other measurements then we could actually calculate the final CR.
The difference in stroke between the 3.2 and 3.5 is 86mm vs 93mm so 7mm or 3.5mm each way. If everything else stays the same and the height of the piston from the middle of the wrist pin to the top doesn’t compensate for this difference of 3.5mm then the CR goes up, but then again you need to take into account piston volume (all the pockets domes and holes).
One could try using the 9.8CR pistons from the TL-P to get something over the 10.0, well im assuming it would go over 10.0 from the bump in displacement. Odyssey/MDX pistons provide for a 10.1 CR before adding additional clearance for the valves.
Old Dec 5, 2008 | 08:21 PM
Allout's Avatar
Blown is Best
From the previous discussions, compression ratio was estimated to be 10.85 using CL-S pistons out of a J32A2.
Old Dec 5, 2008 | 09:21 PM
dam i want dyno numbers
Old Dec 5, 2008 | 10:09 PM
This guy!! Always helps out in a jiffy
Old Dec 9, 2008 | 10:37 AM
gnuts's Avatar
3.5 psi
So what would be the pros/cons to re-using the CL-S pistons? Does higher compression ratio = more power?
Old Dec 9, 2008 | 11:04 AM
dru2's Avatar
Good question!
Old Dec 9, 2008 | 11:14 AM
gnuts's Avatar
3.5 psi
haha, we need answers! From what i understand, higher compression ratio allows the motor to extract more useful energry. But The CR with CL-S pistons is still fairly high.
When you increase the CR is it better to use higher octane gas to prevent knocking? I usually put in Sunoco 94.
Old Dec 9, 2008 | 11:29 AM
artbran's Avatar
666 Speed
hmm... Good point.. well looks like I'm using the CLS pistons and the MDX rods. Just need the crank.. Anyone?
Old Dec 9, 2008 | 12:11 PM
dru2's Avatar
Your best bet is to just buy the crankshaft brand new.
Otherwise, getting a hold of a used 02-04 oddy or 01-02 mdx block and swaping the internals would be a lot more economical.
mlody
Dec 4, 2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
