3.5 conversion
Old Aug 2, 2004 | 01:53 PM
ThinJim's Avatar
3.5 conversion
for anyone who knows. what is your position on the thickness of the sleeves in regards to a turbo application on this setup. what do you think would be a maximum boost before failure to the sleeve would occur?
Old Aug 2, 2004 | 04:19 PM
typeR's Avatar
the sleve...i dont think we'll ever know over 10 not to say the pistons can take much more than that
Old Aug 3, 2004 | 07:01 AM
scalbert's Avatar
With what compression ratio?? Stock 10.5:1 would allow for about 8 - 9 PSI intercooled before many items started to potentially go south.
Old Aug 3, 2004 | 08:21 AM
ThinJim's Avatar
say the rods and pistons have been changed to superior quality and a compression ratio of 9:1 to 9.5:1. also scalbert, i have enjoyed your technical expertise over the short past few months i have been on here. question about your pnp harness for the e manage you have developed. does it add timing as well as retards timing, say in the range of +20 to -20. thanks
Old Aug 3, 2004 | 08:31 AM
scalbert's Avatar
At that point I suspect quite a bit more before the sleeves go south. Possibly in the 15 - 18 PSI range with proper tuning.
Old Aug 3, 2004 | 08:32 AM
kevin79925's Avatar
that would make im guessin a 550-600+ hp cls *drool*
Old Aug 3, 2004 | 10:30 AM
ThinJim's Avatar
we'll see
mlody
Dec 4, 2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
