24v electric supercharger form knights
How do I power up a 24v electric supercharger???, its really big ( not those cheap 12v blowers on Ebay), this gives you real 6psi.
The new ride
a step up transformer can increase the voltage.. if there is one available (for 12 to 24V change) it would enable you to increase the 12V from the battery to 24V for the electric supercharger
Adventurist.
Thomas Knight is very respected around the tuner crowd, his improvements in FI are known everywhere. His E-charger has been around; basically, an electrical nitrous switch without the refills. I've only seen it on one car locally. Would be interesting on a CL
For power, you would either have to run Odyssey batteries or several capacitors to prolong the juice.
Two batteries in parallel sequence?
http://www.yandina.com/24VoltBattery.htm Its for a boat but you should get the idea
Transformers are only for AC not DC
Originally Posted by Hobo
a 10 farad cap would probably accomplish the same thing
Flap.
Originally Posted by kaih
A capacitor would store energy delivering current when needed not additional volts.
thanks captain obvious.
i meant that a system such as this would probaby require a store of energy as someone mentioned it was like nitrous. if you simply use 2 batts when you suck that much current you will create a coltae drop which will eat your alternator and potentially mess with things like abs, pwr steering, and the echarger itself.
03cls6sps/c19"
What there all trying to say is that this is not an effective way to produce more power. You would have to have two additional batteries run in series mounted somewhere(probably the trunk) also you would have to upgrade the alternator to suplly enough power to charge all three batteries. Comptechusa.com?
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Joe Avesyan
09-29-2015 03:57 PM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
