245's 18's rub?w/lowered.....
hey everybody, i'm getting new rims soon and trying to decide what size tire i can go with...i've heard mixed results depending on what springs where used...i've used h&r oe 1" drop...and wanted to know if 245/40/18's would rub or not....will 235's?...thanks alot ....
The largest tires I've seen are 235/35/19 (blxmjx) and 235/40/18 (langjae). Both cars are lowered and both claim no rubbing. Do a search for tirerubbing topics. There is tons of info and debates on tires.
i'm just adding on to the post.
i'm about to get
ADR 18x7.5 gt sports w/
pirelli 215-40-18 p7000 supersport
i will also have the comptech springs.
will these be OK or will rubbing occur? i'm really not too sure on what the numbers mean. thanks
i'm about to get
Originally posted by TypeSDragoon:
<STRONG>i'm just adding on to the post.
i'm about to get
will these be OK or will rubbing occur? i'm really not too sure on what the numbers mean. thanks</STRONG>
i'm about to get
Originally posted by Nashua_Night_Hawk:
<STRONG>Type-S dragon,
you get the wrong tire size.
Get 235/40/18 not the 215/40/18!</STRONG>
plus, will the size of all those tires/rims rub at all agains the comptech springs?
Originally posted by Technique:
<STRONG>Has anyone ever ACTUALLY tried 245's????</STRONG>
This was a while ago...
I never even checked-up on whether the size was available or not. Now that they are going with the S-03, it would be hard to tell, with the older tire line getting "thinned-out"..
I'm starting to wonder if the person who said they rub in the front with their 235/45-17s with SSRs (and Comptech springs) is not telling the whole story.
Perhaps the H&R or other lowering springs make a difference, since there now seen to be some responses that seem to say that they work ok.
BTW -- there can't be that much difference between a 17x8 +48 and 18x8 +50 (with the 235 rubber). Although, every tire has a different contact and section width for a given size...
Originally posted by Brack:
<STRONG>My car (CL-S)has 235/40/18's on 8x18+50mm.
Comptech springs--no rubbing.</STRONG>
Hello :-)
I was the 'someone' who claimed to run 245's
I'm running:
Bridgestone Potenza PolePosition S-02
245/40/18ZR
they NEVER rube in the front... and have made a HUGE performance increase on take offs. But in the back if I have passengers in the back and going faster then usual on street bumps it rubs :-/
My next plan is to get 255's in the front and put 235's in the back... don't know or may just stay with 245's in front and 235's for back... but I'm keeping the 245's at the front... I'd NEVER go back :-D
I'm running:
245/40/18ZR
Originally posted by ramiel408:
<STRONG>Hello :-)
I'm running:
245/40/18ZR
My next plan is to get 255's in the front and put 235's in the back... don't know or may just stay with 245's in front and 235's for back... but I'm keeping the 245's at the front... I'd NEVER go back :-D</STRONG>
<STRONG>Hello :-)
I'm running:
245/40/18ZR
And what are the wheel specs (offset, width, etc)?
k. i'm gonna have 18x7.5 rims on my comptech springs which lower it about 1.5" front 1" rear.
what size tire should i be running on?
225x40x18
215x40x18
225x45x18
215x45x18
i want to still have a comfortable ride, so i should go with the 45's right? thanks
[ 08-07-2001: Message edited by: TypeSDragoon ]
225x40x18
215x40x18
225x45x18
215x45x18
<STRONG>Hello :-)
I'm running:
245/40/18ZR
<STRONG>Hello :-)
I'm running:
245/40/18ZR
Thanks...
i really apperciate all the responses,...i was wondering if any of you have the h&r oe springs w/ 18" rims?...i'm still getting mixed feelings, i really want the extra rubber, but not at the risk of rubbing. from what i read, 235's fit for sure i assume...? thanks.
oh also, if i plan to use a 245 should i go with a high offset(50mm) or lower like 40mm
[ 08-07-2001: Message edited by: crump ]
<STRONG>k. i'm gonna have 18x7.5 rims on my comptech springs which lower it about 1.5" front 1" rear.
225x40x18
215x40x18
225x45x18
215x45x18
[ 08-07-2001: Message edited by: TypeSDragoon ]</STRONG>
225x40x18
215x40x18
225x45x18
215x45x18
Originally posted by crump:
<STRONG>i really apperciate all the responses,...i was wondering if any of you have the h&r oe springs w/ 18" rims?...i'm still getting mixed feelings, i really want the extra rubber, but not at the risk of rubbing. from what i read, 235's fit for sure i assume...? thanks.
[ 08-07-2001: Message edited by: crump ]</STRONG>
i'm still confused on "offset"
225x40x18
215x40x18
225x45x18
215x45x18
they told me that the offset for the rims is 42. and i really dont know what everything means. but i need help on which tire to get on my 18x7.5 rims without rubbing. thanks
225x40x18
215x40x18
225x45x18
215x45x18
<STRONG>i'm still confused on "offset"
225x40x18
215x40x18
225x45x18
215x45x18
225x40x18
215x40x18
225x45x18
215x45x18
Originally posted by EricL:
<STRONG>
But are you lowered, and if yes, what spring(s)?
And what are the wheel specs (offset, width, etc)?</STRONG>
<STRONG>
All I know is that the tires are:
245/40/18 don't know about offsets etc
the RIMS are
Ace Spade HyperBlack 18"
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
