245/40/18 on C5's with 44 offset??
im no expert at this.. but since i read most of the posts about tire size.... so im pretty sure that 245 is way to big. I think you will rub. There are people on this site say that on 18s, that a 235 will rub... so yea.. is im wrong then someone correct me.
<font face="Verdana, Arial" size="2">Originally posted by BDI:
Just curious if they will they fit on a CL-S??</font>
it depends whether your car is lowered or not. if it is then it probably will. typically with your cars the higher the offset the better. type s girl has 19x8 rims with +51 offset, lowered and hers doesn't rub. but others with 18x8 with +43 does with 235.
Good Luck!
<font face="Verdana, Arial" size="2">Originally posted by colbster:
BDI: Just got some 235 40-18's on my cl-s. They had to be custom fitted. 245's will be too wide. If you go with 235 18's be sure to have the work done by a reputable shop since alterations will need to be made to your car. Ask for references and a portfolio. As for me they had to shave my fender wells and actually surface the back pad of the wheels so they would fit(granted I added Eibach springs and brought the car down about 1.6in.). They still even rub under extreme compression. Consolation is that the car looks great and handles as if it were on rails, truly.
Good Luck!</font>
Good Luck!</font>
<font face="Verdana, Arial" size="2">Originally posted by buddha:
do you know your offset. what size rims 18x?. what make?
</font>
</font>
You know, I never even asked about the offset - but I do know that the wheels are 18X8 MASITALY's. I just found the wheels I wanted and my mech fitted them, again had to alter the car to get them to work with the springs.
Location: Somewhere between here and there, yet neither.
You should call tire rack or discount tire...they'll thell you exactly what you need...they even ask if you lowered it..so, if you get a rim pack from them...it is gonna fit.
2001 Cl-S Black on Black with Navigation
Weapon-R Dragon Filter
<font face="Verdana, Arial" size="2">Originally posted by SLAMCLTYPES:
if you get 18 it would look to small get 19
</font>
</font>
![](http://www.acura-cl.com/ubb/smile.gif)
[This message has been edited by so cal type s (edited 02-09-2001).]
</font>
</font>
Hey colbster,
Can you post some pics of your car? I have been looking at those same MAS rims ( actually the Sagittas and the Rogers). I would like to see what they look like.
Thanks, Matt
2001 CL-P Emerald/Parchment
Thanks, Matt
<font face="Verdana, Arial" size="2">Originally posted by mattldm:
Hey colbster,
Thanks, Matt
</font>
Hey colbster,
Thanks, Matt
</font>
01 CL TYPE S: BLK/BLK, CHARCOAL, NAVI, 18" MASITALY'S, EIBACH SPRINGS.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
