2010 rl brake calipers
Old 08-07-2015, 12:36 PM
mattcl-s's Avatar
Hello everyone I been doing some research but I cannot find information about putting 2010 RL calipers on a 03 cls6...do they bolt right up? do I need bigger rotors? can someone help me out with this found some for 250$ seems pretty legit deal
Old 08-07-2015, 12:49 PM
mattcl-s's Avatar
I found a little something that I will need a different brackets to make the rotors work
Old 08-07-2015, 01:11 PM
mattcl-s's Avatar
seems like in need 350z rotors and a bracket anyone know the part number and where I can get them from?
Old 08-08-2015, 07:34 AM
coopcoop30's Avatar
If my memory serves me correctly and it may not. I think they need to be specially made. If you find out who makes it let me know because I would be interested.
Old 08-11-2015, 01:14 PM
3.5 psi
gnuts's Avatar
you can buy the bracket from Fastbrakes. there are a few threads here covering everything.
Old 08-20-2015, 12:47 PM
aznboi2424's Avatar
You need 350Z TRACK edition rotors. They must be for the TRACK edition because they are larger then the regular 350Z rotors.
Old 08-21-2015, 08:09 AM
Scottyknows007's Avatar
Talked to fastbrakes a while back and he also told me you can use a 2010 Nissan Sentra SE-R Spec V rotors. They will fit also and you wont run into the issue of the sides of the calipers rubbing the rotor as it spins.
Old 08-24-2015, 10:37 AM
aznboi2424's Avatar
I never had that problem before.
So does that mean that the 350Z rotors are thicker than the Sentra rotors?
Old 08-24-2015, 02:46 PM
That's what it sounded like. He was telling me that some people were actually grinding down the inside of the caliper to clear the rotor, and that the Sentra should work better and not have this problem. But it WASN'T guaranteed... it might still rub
Old 08-24-2015, 02:52 PM
mattcl-s's Avatar
waited to long looking for this bracket and calipers were sold... oh well
Old 08-30-2015, 12:33 AM
bigdaddyKA8's Avatar
They come up on the BM pretty often if I recall correctly. I have a spare set I may be selling soon.
08_UA7_Gr33k
02-11-2016 02:17 PM
johnalfa
11-05-2015 06:44 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: 2010 rl brake calipers
