2003 Eclass unveiled (big pics)......
Technical innovations standard/optional
Active seat ventilation: Mini-ventilators allow air to flow through the seat interior. optional in conjunction with leather upholstery
Adaptive accelerator pedal: The engine characteristics are adapted to the personal driving style. standard in all petrol
models
Adaptive front airbags with two-stage gas generators: Driver and front passenger airbags inflate according to accident severity. standard
Air control system: A microprocessor closes the lower air intake depending on the driving situation, improving the Cdvalue. standard in models E 240 and E 320
AIRMATIC DC: The enhanced air suspension now adjusts the springing and damping according to the driving situation. optional/standard in the E 500
Auxiliary ventilation: Solar cells in the roof supply the power to drive the ventilation fan of the automatic climate control system, cooling the interior when the saloon is parked. optional in conjunction with panoramic sliding sunroof
Belt force limiters: During a crash this system reduces the forces exerted on the occupants by the seat belts. For the first time belt force limiters with adaptive control are fitted for front seat occupants. standard, on the outer seats in the rear
Belt tensioners: Any slack in the seat belt is instantly taken up during a crash. standard, on the outer seats in the rear
Bi-xenon headlamps: Powerful gas discharge lamps for dipped and high beam improve safety at night. optional/standard for AVANTGARDE
"Bluetoooth" telephone: Fixed telephone installation allows cable-free telephoning in the interior of the new E-Class. optional
Child seat recognition: A transponder system automatically detects whether a rear-facing child seat is installed, in which case it deactivates the front passenger airbag. standard
COMAND APS: The system integrates radio, DVD player, TV unit, navigation system and telephone operation. optional
Crash boxes: Energy-absorbing elements in the front end can be inexpensively replaced after a minor collision. standard
DISTRONIC: Intelligent cruise control keeps the E-Class at the right distance and eases the driver's workload. optional
Dynamic multicontour seat: The backrest contours automatically adapt to the driving situation. optional
Easy Entry: When getting out, the steering wheel automatically moves upwards and the seat moves to the rear to allow the driver more freedom of movement. optional
E-mail: E-mails appear on the Audio 50 APS and COMAND APS display if a telephone is installed. optional
ESP®: This dynamic safety system reduces the risk of skidding. standard
Four-link front suspension: A new design improves wheel location, comfort, directional stability and steering precision. standard
Four-zone THERMOTRONIC: This newly developed system enables the temperature and airflow to be individually controlled for each of the four seats. optional
Headlamp Assist: A sensor on the windscreen detects when darkness falls and automatically switches the vehicle lights on. standard
Heated steering wheel: Heating wires warm the rim of the steering wheel. optional
Heater booster: An electric heater booster ensures a comfortable temperature. standard in the CDI models
HP bulbs: New "High Performance" bulbs last the entire life of the vehicle. standard
Infra-red reflection: The windows reflect the infra-red component in sunlight, thereby improving climatic comfort. optional
Integral child seats: The child booster seats emerge from the rear seat unit at the touch of a button. optional
KEYLESS-GO: The doors and boot lid may be opened without the use of a key. optional
Key-operated memory function: The seat and mirror positions as well as the settings for four-zone THERMOTRONIC are stored in the microchip of the electronic ignition key. optional
Lightweight construction: The bonnet, front wings, boot lid, front-end/rear-end modules and parcel shelf are of aluminium. standard
LINGUATRONIC: The radio, CD player, telephone and now also the navigation system can be voice-controlled. optional with Audio 50 APS or COMAND APS
Multifunction steering wheel: The radio, telephone, navigation system and other units can be operated from the steering wheel. standard
Panoramic sliding sunroof: The glass roof extends from the windscreen to the rear end. optional
Rain sensor: The windscreen wiper is now variably controlled according to rain intensity. standard
Sensotronic Brake Control: This electrohydraulic system improves safety when braking in an emergency. standard
Short Message Service: SMS messages are shown on the display of the Audio 50 APS unit and COMAND system if a telephone/mobile phone is connected. optional
Sidebags: Air cushions along the sides reduce the risk of injury during a lateral impact. standard for driver's and front passenger seats
Sound system: A new multi-channel system provides surround-sound on every seat. optional with Audio 50 APS or COMAND APS
TELEAID: An SOS message is automatically sent and relayed to a service centre in the event of an accident. optional in conjunction with fixed telephone installation
TELEDIAGNOSIS: Important data for breakdown assistance are relayed to the Mercedes-Benz Customer Assistance Center at the touch of a button. optional
(TELEAID is a technical requirement)
THERMATIC automatic climate control: The system operates with a humidity sensor and infinitely variable compressor. standard
Tunnel closing: Pressing the air recirculation button closes all open windows and the sliding sunroof when entering a tunnel or underground car park. standard
Tyre pressure monitoring: The air pressure of the tyres is automatically monitored. optional
Underbody panelling: Large plastic panels replace the previous, environmentally questionable PVC anti-corrosion protection. standard
Upfront sensors:
Crash sensors in the front end enable the restraint systems to be activated as the situation requires.
standard
Weight classification: A measuring membrane in the seat registers the weight of the front passenger and uses these data to activate the airbag according to the relevant crash situation. standard
Windowbags: The large air cushion extends from the A-pillar to the C-pillar like a curtain during a crash, reducing the risk of head injuries. standard
models
Upfront sensors:
standard
Originally posted by CL-S-Bo
Is it just me or does that interior look like our beautiful bowling ball trim? Anyone have any ideas when these babies will be out on the lots? I heard that they may release the E and CLK models early this year.
OK, not to bite off of Soopa's terminalogy, but damn.... that thing is TITS!!
wow, so freakin' hot. I'll have to keep my eye on that down the road.... I'm also curious about the new CLK.... I could be in trouble here!!
dayum that car is fucking sweet. although i hate that panaromic or whatever roof - glad that's optional. i really dislike the current e-class and i'm glad to see how much they've improved it. i would buy one in a hearbeat if i had the $$$. very, very nice. is that a manual tranny i see?
The interior
I think that is real marble. I read somewhere that they were going to start using it because they found a light weight way to put it in cars.
I love the roof. It would be a wonderful change from the current porthole that we have. I think it would only look good for the black ones though.
What's up with the damn red triangle though. Thats one thing I have never understood about Mercedes. It's like that red triangle is the centerpoint of all of their interiors. Albeit it is a darker color now, it still sits right smack dab in the middle of everything. Are hazard lights that damn important to M.B. owners?
"Easy Entry: When getting out, the steering wheel automatically moves upwards and the seat moves to the rear to allow the driver more freedom of movement. optional "
Hmmm...this was STANDARD on my 1990 Infiniti Q45....it also had blue-tinted side mirrors long before the TL...
Other than that...What a dope ride..love the gauges..can't wait to see what Lorinser, Brabus, RENNTech and CEC have for it..
Originally posted by Red Nj-s
I think its aight. Sumin about resembling the C coupe thing is makin me think it looks low rent. Finally they put a manual in it. I am sure i'll warm up to it when it comes out.
MB!
It looks like bigger C Class.. The current e-class looks bigger... All the option and things are cool I hope the didn't make it smaller Cause it looks that way to me..
Nicey nice. MB did a great job on the new e-class. I always hated the rear of the current e class. Finally looks deserving of its 40k+ sticker price.
Is there an option for a nav unit?? I doesn't look like it would be possible.
Pham Alvan
03-16-2016 09:17 AM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
