2003 Cl-S 6MT Misfire Help
Any ideas on what might cause a random misfire code? I have 2003 cl-s 6-speed (190,000 miles) and have replaced spark plugs and coils, EGR valve, plenum gasket, throttle body gasket, and power steering pump (It needs a new rack and pinion). It needs a valve adjustment as well, which is what my buddy thinks it is, but I'm thinking of either a crank position sensor or maybe a fuel pump. I love this car but this misfire is making me go insane. Any order in which I should do these repairs if you think it is one of these problems? ANY advice would be greatly appreciated. (yes I should have done the valve adjustment while I was already in there but I was hoping each time the other fix would do the trick and I don't have the expectance to know how much drag there should be).
PS I just bought this car and I am brand new to this website, I accidentally posted this in an old thread, so I figured id make anew thread? Hope that is allowed.
Have you considered the fuel injectors? They might be slightly worn after 190K.
In addition, if it is a six-speed, with an unknown history to you because you just purchased it, also consider bent valves from a possible over-rev situation.
All the threads I've seen here, in the past, when either crank sensor is bad usually the ECM sets a P0336 Crankshaft Position Sensor A, located behind the crank pulley, and Codes P0385,P0386 in regards to Crankshaft Position Sensor B, which is located on the Transmission Bell Housing.
eliii (03-31-2021)
I'm gonna take it in a get a valve adjustment and pray the valves are not bent guess. I can hear them clicking so I know it needs to be done regardless. Anyway, how would I go about checking if the fuel injectors are bad? I was thinking it could those as well but the fuel pump is a much cheaper fix lol.
eliii (03-31-2021)
Sports Talk & Fantasy Leagues
404
08-31-2021 01:21 PM
Stampede1
1G TSX Problems & Fixes
06-13-2020 01:29 PM
Chris M. Dickman
05-28-2020 03:14 PM
