13.28@105.34
#41
Originally posted by CiLver2.3
NIIICE!!!!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Glad my stuff is getting good use!!!
NIIICE!!!!
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
#42
Originally posted by want_updohg?
only a handful of members on this board have gotten that time or better.
not trying to brag. :o
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#48
Originally posted by ga2000
great times bro what tires do u have
#49
Sold 12/29/04 :-(
Re: 13.28@105.34
Originally posted by mattg
thats what i ran on my final pass this afternoon, gentlemen.
:bananahump:
it was 80 degrees, mostly sunny.
i'll be back later to post more details and the slips.
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
![Rock On](https://acurazine.com/forums/images/smilies/rockon.gif)
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
![Jump](https://acurazine.com/forums/images/smilies/jump.gif)
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
I guess the UR pulleys do make a big
BTW: You said this was your last run. What times/mph were your other runs fo the day?
#53
Parting out 02 Type S :(
damn it steve, we know you have over 300 hp to the wheels with more coming, get to the track already and show what comptech BOOST can do for ya!
this applies to cls6sp as well!
#55
I don't know if I can beat that ET though.
#61
as long as your 60 is around 2.1, i see no reason why you cant at least match the et. what do you think your mph will be?
I am shooting for 110+, maybe 112 MPH.
The problem is that Atlanta Dragway isn't the fastest track out there. It isn't always well prepped. It is in the south so heat and humidity are a problem. Also, the track also sits at about 1200 - 1300 feet.
I might need to head down to Silver Dollar Raceway which is in central Georgia. But is 2.5 hours away.
#64
Originally posted by scalbert
Yea, but I don't think I can lay a 2.1 down on street tires. I expect my short time to be at best a 2.35.
#65
Originally posted by allmotor_2000
I think you'll hit 112mph - you probably have the same or more hp than I did last time; that was at ~1K elevation
But one street tires and with me driving I don't know about the ET. :o
#69
Originally posted by mantis23
Did you spray off the line? if not, at what RPM did you hit the funny stuff?
i will be posting the 5 slips along with how i launched, shifted and sprayed each run.
thanks again guys for your posts.
#71
on the 13.2 run i sprayed out of the hole. i did a slight tb, waited until i had traction then i rolled into WOT. it hooked up really well that run.
#73
I will by next fall. But for now I want to know what it can run in street trim.
E.T. Streets on the other hand - they help some
#74
Sold 12/29/04 :-(
scalbert or allmotor,
Can either or both of you comment on the UR pulleys that mattg has on his car? It is very obvious that they make a noticeable difference because we have the same setup EXCEPT I have AEM pulleys & mattg has UR pulleys.
I know that the UR pulleys replace the crank pulley while the AEM does not. I have heard that when you change the crank pulley you can cause problems because of the harmonic balancer or something like that. Is there any fact to this, or is it just a myth?
#75
Sold 12/29/04 :-(
Dyno results from just the crank pulley upgrade:
Chick Here
Chick Here
#76
So, would I recommend it to the fellow enthuasiast - YES, if they are running NA and don't necessarily want to race the car to achieve its 100% potential. If you are running FI or want to push the limits of the motor, don't do it.
#78
Originally posted by BC
Did you have to deploy the chute?
PIR? Woodburn?
Nice time. Used to be a car had to have a big honkin' V8 to be that quick.
PIR? Woodburn?
i was at Woodburn.
#79
Sold 12/29/04 :-(
The AEM doesn't do anything. The UR is lightweight and underdrives the accessories. On the issue of whether its reliable etc. I haven't heard of any detrimental effects caused by the UR Pulley itself - several members have done oil-analysis etc. I don't attribute a significant improvement to the UR Pulleys - not more than 0.5mph in the 1/4-mile. I have done a lot of reading on crank vibrations/harmonics etc. after all my clutch problems and have come to realize that the pulley design is critical to long-term engine reliability. To those taking the car to 6.8K RPMs... its not a big issue. To those pushing the limits (7.2K and upwards), it could be a problem!
Originally posted by darrinb
sfla...
def get the UR pulleys, i got just the crank and as soon as i pulled out of the shop i noticed the revs spinning free'er, def gets ya out of the hole quicker
sfla...
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Allmotor says, "If you are running FI or want to push the limits of the motor, don't do it"
and
Darrinb says, "def get the UR pulleys, i got just the crank and as soon as i pulled out of the shop i noticed the revs spinning free'er, def gets ya out of the hole quicker"
What do I do?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
#80
What do I do?
What do I do?
Allmotor is basing his opinion on experience when pushing it on this engine. He certainly has this and other experience in which to make an educated opinion.
But honestly it is unknown at this time. We'll have to see what occurs later when engines are pushed with the pulley. It might be just fine; or it may not. But without significant equipment and testing we will just have to wait.
