1. Brakes 2. covered or not covered?
CLS 5AT 03.... I don't really beat on brakes that bad, but I wouldn't say I drive like a granny either... wondering what my best braking options would be... My front brakes are squealing right now but theres no vibration at all in the steering column so its not the rotors, i know that much...had my CL almost a week now...bringing car to acura dealer wednesday because tranny is slipping, check engine light on, installing OEM spoiler, side airbag light flashing occasionally and also the pass. heated seat is not functioning... guessing i should go to the dealer i bought the car from before wednesday to check brakes, hopefully they'll give me new pads free?...My last question is if i get new rotors like the rotoras, do they need to be professionally installed or can it go to a mavis discount tire type place? and do they take different pads... i'm so lost...
3.2 VTEC
Just cuz your brakes are squeeling doesn't nessisarily mean they are worn out and need replacing, unless they squeel real bad and that's to tell you you need to change them. For example ceramic pads tend to squeel often even if they are not worn out at all. As far as changing your rotors, it's never bad to chnge them and anybody that can do your brakes can do the rotors as well, they shouldn't even charge you for changing rotors. When you replace the brakes you have to take the caliper out of it's place, and then the rotor is 2 screws away from comming off, it wud literally take you 1 minute or less to do once the caliper is off. The pads are gonna always fit no matter what rotor you put on them, unless it's a big brake kit and it's a different size caliper and rotor.
I dought that ebay auction is a fake, but yes that does look like a good price. Wether you need new rotors or not is another thing though...but if you change them atleast they wud look more flashy being drilled n all
Good luck with the A/T...no matter what it's under warranty for a while so u shud be good on that, as far as the brakes, it's a wear and tear part so i'm almost positive they won't replace them for free, but who knows, since you just bought the car a weak ago you could try them and see if they'll change them for you since you were not the one that wore them out, you got it like that.
good luck...
good luck...
Former Sponsor
Originally Posted by kartman232000
too good to be true?? http://cgi.ebay.com/ebaymotors/Acura...53071096QQrdZ1
if you bought from a non-Acura dealer, they probably put jobber brake pads, the reason of the squealing.
i suggest you get yourself better brake pads (i even suggest better than acura original)
Don't Mess With Texas
wow
that many huh? lol musta been high when i posted that first one, those rotors are definitely crap... should be good on posts for a bit now... but i will say this forum has given me a great deal of help and i'm sorry if some of the posts were a bit rushed and uninformed...
ABP CL-S 6 NAV
hahaha. I was gonna say the same thing. I think kartman started threads regading his new car, rotor questions, transmission problems, rims, loaner cars.
welcome to AZ too man. you got any other questions?? lol
Originally Posted by cltypeSLOW
I knew I remembered that.
Like Excelerate said, they are real. The problem is quality. I would say though that if it's squeeling, it's more likely that your pads suck. Try those first. If you need new rotors....I would go with Rotoras. If you do a search, you would find that a lot have been said about those e-bay rotors.
SidhuSaaB
05-30-2020 12:40 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
