09 upper intake .. need help
ok well thats not what i thought id seen in the one shot of the lid id seen in anaother post ... i thought the butterflies were parallel to the lid and the lid had a small dome to it atleast to its inside ... so basically ....
NEVERMIND RES back to dead ... no but really what still could be done is that spacer SCalbert had made way back get used to gether on original manifold but use '09 lid essentially what im saying is add about the height of the butterflies from the '09 lid as a spacer and have two sets of butterflies the ones in the -01-03 manifold and the ones in the '09 lid open same time
3.5 psi
you mean a spacer between the manifold and runners? Some people have used the MDX spacer. You can mill it down a bit for better clearance too. I have an outlaw spacer for sale...it's about a 1/4" i believe.
no a spacer between the lid and the manifold increasing plenum volume
Whats up with RDX owners?
I dont see how that spacer will make any power (and in one of Scalberts posts, he mentioned performance was damn near the same as stock).
The plenum spacer is a good place to pick up some power though.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
i realize this is just speculation but what ur not getting is this would change the design and maybe the out come ... im suggesting that we might try a stock manifold ... scalberts spacer design ... and an '09 lid thus having 2 sets of butterflies now when they open there wouldnt be a stack to the added volume ... it would all be exposed
3.7L Nitrous Breathing CL
If you were able to slice the top of the manifold off and added material to increase the manifolds height that would be the best way to gain your volume and still keep the flat cover.
best way to gain on the stock manifold design would be plenum spacers or Somesort of custom work to the tb neck of the manifold.
Have you tryied messing with runner lenth or taking material out of the inside of the manifold ?
I see but, what are you trying to compare ?
The porting of the upper ?
Do you have any pics of the port job to the inner manifold ?
Did you take all the weight you could inside the manifold out to increase volume?
because even thou I did mine,I think their is more that could come out.
I will start busting out more pics when my car is up perfectly again. When I am moving forward with the car.
I'm not trying to take anything from you.
I like seeing new stuff because the maker is the Ginni pig for the rest of us.
rcs86
08-02-2016 06:52 PM
adreano17
09-29-2015 08:48 AM
