Emergency Brake Check?
My kid drove my 01 CL with 77K home yesterday from an errand (about 1 mile at 30 MPH with a few traffic lights) with the emergency brake on. The brakes still seem to work fine. I hardly ever use the e-brake. Is there anything I should check on it?
The one and only time I forgot my e-brake on, I took the car up to over 100mph for about 2 miles up while up north. Noticed a weird shaking at those speeds. Got to the place I was headed and realized the brake was on. Checked everything out on a lift back at the house later and everything was fine.
the e brake is contained inside the rear rotors.. visual inspection wouldn't tell you anything.. only way you'd know if there is damage is by removing the rotor and checking the shoes/pads and see if there is any serious wear on the rotor itself. most likely nothing will neeeed to be replaced.
the e brake is self adjusting supposedly so unless the ebrake is no longer doing it's job.. then i'd start looking for the culprit
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
