03 CL 6-speeds ( and 6spd TLs )
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
2 Questions for all of you CL and TL 6-speeders:
? 1 - At how many miles are you: a) currently at with your stock clutch OR b)at when you replaced your stock clutch? Aftermarket clutches tune in too, im curious about those too.
I am at 71K miles in 03 CL with my stock clutch and it still feels good, no slippage so far..
? 2 - How about your brakes? - i just replaced mine at 70K. Generally, i rarely use my brakes for normal deceleration so I'm curious about everyone else..
Just turned 51k miles in my CLS 6MT. It's got all the CT goodies (i/sc/h/full-catback, etc...). The stock clutch still feels good even after 30K miles with the sc. As for the brakes, I replaced the OEM's at about 25k miles with the front Brembo BBK and the rears with cross-drilled.
Originally Posted by spdy0001
23K miles
Downshifting is the key to saving brakes
2) Brakes are just fine. Last time I looked, at around 79K, I had about 35-40% left on the pads. Mostly hwy driving and I shift down.
Originally Posted by NSX-Tuner
But can also lead to excessive drive-train wear is over-used. Brakes are a whole lot cheaper/easier to replace and/or repair too.
I have 118k on a 98 S10 ... original clutch ... still seems good, but I'd expect it to go bye bye 125-150k.
It depends how YOU drive stick, how much city driving you do vs freeway, and so many other factors!
EDIT:
I'm not saying you'll wear out the drive train ... but the constant engaging and disengaging of the clutch uses clutch-life & surface. Not to leave out the extra gas consumption from the non-idle RPMs.
Originally Posted by Starter
??? Not if you blip the motor to match drive train RPMs (double clutching). Haven't worn out a clutch yet, on any car, with hard driving and well over 100K on most of them.
Stock 03 CL-S/6 @ 57,000 miles
Clutch is fine
Front rotors are warped and have been for a while. Pads are probably pretty thin by now. Going to have both replaced at 60k service.
Clutch is fine
CLS 6MT Navi
03 CLS 6 speed at 25k miles, no problems with clutch or brakes. it's true, it's smarter (cheaper) to use the brakes to slow than the tranny, but I do both too.
i do a lot of coasting in neutral now to slow down, saves on gas and brakes.
I now drive an accord....
True, but most people don't bother or know how to properly double-clutch and rev-match, not to mention heel-toe.
First of all coasting in neutral is hazardous, because what are you going to do if you need to accelerate to avoid an accident? I won't argue with you on the gas thing, its not worth it
45K in my 6spd CLS...no clutch issues so far; dont anticipate any for over 100K. Brakes are showing some sign of pulsation...plan to have them checked and probably have rotors cut shortly
ex 6 Speed owner :(
Only 9,241 miles so not really applicable to your questions. The clutch slips if I floor it in 3rd or 4th... mostly due to the excessive torque.
Relax!
Ok, ill do it...sharing knowledge is key...
If you leave your car in gear while you coast, you use the momentum of the car (wheels/transmission) to keep the engine turning....no gas. On the other hand, when you put the car in nuetral you are burning gas to keep the engine on.
"It's sexy time!" (borat)
2003 CL-S 6 speed.
44K
Clutch like brand new
And i just bought Brembo rotors yesterday. I had a lot of vibratrion in my stopping. This should fix the problem.
44K
Originally Posted by ANDY03CL-S
2003 CL-S 6 speed.
44K
44K
Blown is Best
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
at 74K Km, clutch still feels fine.
Front Rotors have been turned twice and a new set of pad...all done by the dealer due to warping issues.
I do a combo of downshifting and/or braking depending on situation (and how fast I can take the off ramp
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
96k Miles on stock clutch
Rotors have been cut, and now replaced and pads have been replaced 2 times and I have warped my latest set of rotors. I would still contribute this to calipers over rotors/pad selection.
I'm also on my 3rd set of tires.
ex 6 Speed owner :(
Originally Posted by Allout
Put 27K on the stock flywheel and clutch. Swapped to Comptech Flywheel/ clutch combo and have put 15K miles on it. So far- so good ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Blown is Best
Originally Posted by BlueCLS6
Do you find the Comptech clutch disc grips better than the stock unit? I am in need of a stronger clutch but would like to include the lightened flywheel with my upgrade. Comptech says it was designed for their S/C'd applications so one would assume it can hold more torque. However I don't see how much of a difference just the clutch disc would make without the addition of a new pressure plate to increase the clamping force. Thanks.
Stock Clutch - 12K miles (not much wear at all)
Comptech Clutch #1 - 1500 miles then broke
Comptech Clutch #2 - 150 miles then broke
Comptech Clutch #3 - 200 miles then broke
Stock Clutch #2 - 35K miles with nearly 500hp and 400 torque to the clutch... no problems!
I bought my CLS-6 this summer, with about 55K miles on it. I have no idea how the previous doufus drove it, but the clutch slipped badly the first time I tried to race someone. When they pulled it apart to replace the friction plate they found that the flywheel was totally cooked, so I had to replace both. There are very limited options for after market clutches... with Comptech being really the only option, and there are mixed reviews on the CT clutch / flywheel combo.
After reading Allmotor's post I am really glad that i didn't go for the CT clutch.
So... I don't really agree with your statement that you burn NO gas when using the engine to brake... it just doesn't seem logical to me.
05 C230K & 09 135i 6MT
Gas consumption is largely based on throttle input. If you're not touching the gas, you're not using much, if any (using the momentum, as mentioned). I'd like to see some official info on it, though.
I Heart 6 Gears.
27K on my CL-S - the clutch is great (I can still chirp third); I downshift regularly, but not as to put a lot of strain on the clutch. The low miles - I ride my Harley anytime I can.
Logically I would say the higher revving will consume more fuel as the cylinders are firing twice as often... and fuel must be consumed for combustion. Gas consumption is definately a function of throttle input, which normally is correlated to RPM. In this case, RPM increases are mechanically induced rather than by throttle stimulation, so I would expect consumption to be less than say WOT, but more than idle.
Would appreciate a professional opinion on this as now I am curious...
I'm a Vagiterian.
Originally Posted by JDMj20acL
Aint that some shit.. Lol Hey Ramanan I always read your article in Turbo mag. I cant ever seem to get enough of it!
Originally Posted by goredcar
Agreed... but what we are really comparing is revving at 2+K or idling, both with no throttle input.
Unless the fuel injectors shut down completely during 0% throttle engine-braking, there's no way that letting the car idle while using your brakes consumes more gas.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Lets assume you guys are right and you are saving "some" gas. It won't be enough for you to tell at the pump. Plus you are still being unsafe by coasting in neutral.
Originally Posted by All Mine
He writes in turbo? Cool. I'm going to have to subscribe to it just for that reason.
(no sarcasim)
I am not sure I buy the safety thing about keeping the car in gear. I can't recall the last time that I had to accelerate to avoid an accident when I was coasting to a stop light. I can on the other hand recall when I had to use the brake... and my foot is already on that pedal when coasting.
To be be fair, I notice that when coasting in neutral, it takes a hell of a lot longer to slow down than coasting in neutral... of course requiring more brake pedal.
