~cutting Plexiglass~
Old Mar 20, 2002 | 12:48 PM
CWEET CL's Avatar
HITTIN' DA SWITCHES DAILY
Does anyone know the best way to cut plexiglass its about 1/4 in. thick do i have to take it to a shop to get it cut?? or is it something at home I can use??
Old Mar 20, 2002 | 12:49 PM
NOVAwhiteTypeS's Avatar
Saw, or take it to homedepot.
Old Mar 20, 2002 | 12:51 PM
6speed's Avatar
I used to cut the stuff when I was in the picture framing business. Get a plexi knife. You score the cut several times and then snap it. Don't peel the mask until after you make the cut.
Old Mar 20, 2002 | 12:52 PM
bnavarro's Avatar
Got BOOST????
home depot sells a special knife that scores it to cut it
Old Mar 20, 2002 | 12:54 PM
CWEET CL's Avatar
ok thanks this special knife is it easy to use or will i be needing some new stitches lol
Old Mar 20, 2002 | 12:55 PM
bnavarro's Avatar
Got BOOST????
yea, it's easy. the knife is curved and just drag it accross the plexiglass. just be carfull
Old Mar 20, 2002 | 07:31 PM
acura_service's Avatar
www.drippinwet.com
i make license plate covers out of 1/4 all the time, cut it with whatever you want, sand edges, - then buff out on a benchgrinder with buffing wheel and plastic compound, edges come out crystal clear
Old Mar 20, 2002 | 07:52 PM
4pumpedCL's Avatar
Honkey
I was also in the picture framing business. Just buy the cutting device at home depot and score it about 4 times applying a fair amount of pressure. Then, with the cut up, bend the plexi in half and it ought to break on the line you cut. You can also cut it with a really fine toothed jigsaw. Make sure it's secure, if it startes shaking all over the place you may crack it. Good luck
Old Mar 20, 2002 | 07:56 PM
fast_daddy_car's Avatar
I use a roto-zip tool mounted in a portable b&d vise table. I move the plexi over the cutting bit. Very fast, easy to control, does all kinds of shapes easily.
Old Mar 20, 2002 | 10:37 PM
Nicky Pass's Avatar
Fuct in the hed!
They make special saw blades for cutting plexiglass.
Old Mar 20, 2002 | 10:53 PM
EricS's Avatar
Rotozip works wonders:
Old Mar 22, 2002 | 09:22 AM
CWEET CL's Avatar
Hey i tried the jig saw deal once it cut it right but it was getting so hott the plex was melting back together after i cut it i havent got this special blade yet but the rotozip deal looks sweet i may try that for real thanks CL brothers...
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
Timmy18
Oct 17, 2015 03:58 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
polish_pat
Sep 25, 2015 12:24 PM
