*help-P0123 Throttle Position (TP) Sensor Circuit High Voltage
Old Aug 28, 2012 | 07:26 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Got my car back together this weekend and am still in limp mode because of this code. We tried calibrating the tps to read the correct voltage, but the sensor needs to turn a little more if you know what I mean, so I'm thinking of dremeling the mounting holes a little in order to get a little more turning radius out of it. Anyway, the code is P0123 Throttle Position (TP) Sensor Circuit High Voltage. I'm running a skunk 2 70mm tb with all oem sensors. Any ideas?
Old Aug 28, 2012 | 10:21 AM
6mt swapped..smart
SAME problem to a tee that i'm having
https://acurazine.com/forums/showthr...ighlight=P0123
Dec 7, 2020 05:39 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
HeloDown
Sep 8, 2015 06:51 PM
