View Poll Results: What kind of problems have you had with your XS headers?
Leaks due it fitment or bad seals?
12.59%
Cracking due to poor quality welds?
7.41%
Other (please specify what it is) ?
7.41%
None?
63.70%
Excessive resonance?
18.52%
Multiple Choice Poll. Voters: 135. You may not vote on this poll
*** XS Power Header Owner Thread ***
Old 06-17-2008, 02:22 PM
  #321
I Wanna Beer
TheWeez's Avatar
Anyone need to replace the header to the block bolts or are those reusable?
Old 06-17-2008, 04:11 PM
  #322
Quarantuning
SlickShiftNall6's Avatar
You mean the head studs? All you need to do is remove the nuts holding the header manifold to the head. The studs stay in the head, do not strip them!!!!
Old 06-17-2008, 04:16 PM
  #323
I Wanna Beer
TheWeez's Avatar
Sorry, meant new bolts. Stupid things are like $2-3 each at the stealership and you need 10 of them. I assume they should be able to be reused? Car is from TX and has only seen 1 MN winter with 80k miles on it.
Old 07-08-2008, 09:15 AM
  #324
AJ's Silver CL's Avatar
I got my XS headers installed a week ago. They are great !!! No resonance what so ever.
My mechanic reused the stock gaskets, used new bolts and rewelded them where they connect to the block.
I dont know if this different from what other people have done, he hand tightened first then bolted them down.
Old 07-08-2008, 03:29 PM
  #325
I Wanna Beer
TheWeez's Avatar
Did you have the flex-pipe wrapped?
Old 07-08-2008, 11:42 PM
  #326
sayfulhaqq's Avatar
Damn man, get those headers installed already!!!! The flex pipe wrap is not really needed, I did not wrap mine and mine sounds perfect, I think you have done your fair share of research now just pull the trigger and get everything installed ,ahah.
Old 07-09-2008, 01:31 AM
  #327
I didnt wrap the flex pipe. You dont need to wrap the flex pipe. The resonace is from poorly installed headers.
Old 07-09-2008, 06:30 AM
  #328
duCksterz's Avatar
how much they will charge u to slapp on headers for ?
Old 07-09-2008, 08:58 AM
  #329
My mechanic installed them for $100, and rewelded for a $100.
Old 07-09-2008, 12:48 PM
  #330
duCksterz's Avatar
wat u mean by rewelded? it doesnt fit properly?
Old 07-23-2008, 08:48 PM
  #331
02CL-TypeS's Avatar
hey guys...I have some questions and this is a long as thread otherwise I wouldn't mind reading a couple pages for an answer.
1) What are the oem gasket part numbers. I'm going to use the circle gaskets that come with the headers.
2) What are the bolts that I need to replace...I will buy them from the local auto store...any nuts required?
3) BTW, how much should installation run at a shop such as Meineke or Firestone?
thanks
Old 07-23-2008, 09:13 PM
  #332
The welds can crack where the header bolts up to the motor, so he welded over the original welds.
Im pretty sure alot of people have craked xs headers and dont realize it. 2 of my friends cracked, they didnt notice until they removed the headers !!!
Old 08-20-2008, 10:51 AM
  #333
CivicB18B1's Avatar
shit i lost my gaskets that come with my headers! (the metal rings) what can i do? it is possible to buy the same size at the acura dealer?
Old 08-20-2008, 11:27 AM
  #334
p.diddy's Avatar
yea you can buy them from an acura dealer. you shouldn't use the ones that come with them anyway there pretty shitty.
Old 09-11-2008, 02:51 PM
  #335
Your mom is in
thevikas87's Avatar
What is the part number for the OEM gaskets?
Old 09-11-2008, 03:49 PM
  #336
Your mom is in
thevikas87's Avatar
oh and how many of the 10 x 30, or 10 x 40, bolts will i need?
8?
Old 09-11-2008, 07:40 PM
  #337
Your mom is in
thevikas87's Avatar
Also would the gaskets from honda for the 98-02 accord work?
Old 09-15-2008, 09:46 PM
  #338
calvinnguy3n's Avatar
i ordered my second set of xs power header due to my set being dented to shit. and unfortunately they are different from the first set i had from about 2 years ago. i ordered directly from the xs power website and i received the header with 2 flex pipes on it. does anyone know what's going on?
Old 09-15-2008, 11:09 PM
  #339
I Wanna Beer
TheWeez's Avatar
Very strange. I ordered mine a couple months ago and they only had the single flex pipe. I'd contact them and see if they changed design or if you got one of those pairs that another eBay company has been selling somehow.
Old 09-16-2008, 12:01 AM
  #340
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,157 Likes on 4,817 Posts
I ordered mine about 3 weeks ago and I've only got one flex pipe. Definately call them.
Old 09-16-2008, 04:43 AM
  #341
4drs just wanna have fun!
Accord_V6_400m's Avatar
So has anyone compared the Comptech j-pipe to its XS counterpart?
It seems like there is a big difference, Comptech is just 2.0" throughout, never bigger never smaller. While for the XS headers they offer this summary:
HUGE PRIMARY TUBING FOR MAX POWER !
2.5" COLLECTOR, 2.35" INLET
ALL DIRECT BOLT-ON TO ANY AFTER-MARKET 2.25"-2.5" CAT BACK
Seems like a pretty good difference in size when compared to 2.0" and using "stock gaskets" I swear, sometimes I think the only way the Comptech headers make power is simply by the better designed shorty headers that have a 2.0" outlet and not the 1.75-1.8" outlet stock. Don't remember the outlet size on the stock j-pipe but I think its also 2.0".
Old 09-16-2008, 09:35 AM
  #342
I Wanna Beer
TheWeez's Avatar
I thought the XSPower was pretty much an exact copy of the Comptech and that was the reason they were pulled from eBay?
Old 09-16-2008, 11:26 PM
  #343
Not quite, as you can tell they have j-pipe differences that I would like to take advantage of, anyone else have some insight on this? Kind of defeats the purpose of having stock piping diameter of 2.25" when the collector is 2.0"
Old 09-17-2008, 07:25 AM
  #344
fuzzy02CLS's Avatar
I've had both, I didn't notice a difference in tube size.
Old 03-26-2009, 04:37 PM
  #345
B A N N E D
StonedCL's Avatar
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Bringing this thread back from da dead!
Lot of GREAT stuff here...I want to get some of these headers after I install my suspention and run into some more money! (done doing all the maintence to my car so need a new project) Are these the headers they sell on ebay from 80-100 dollars? Is there a website I can still buy these at cuz one of the site posted in this tread does not work anymore the other place says its sold out , so is there a store or do I gotta go on EBAY?
The ones on ebay dont have a name no ss chrome or xs power headers but they look like them and are priced like them (CHEAP) so I needed to know!
The dealership I work at is going down in a month so I want to get my car fully upgraded b4 they closed cuz I got tools and techs willing to help for some BEER and FOOD! Best way to a techs heart BEER AND FOOD LOL!!
I though bringing this tread back will help the newbies out also with header questions cuz its ALL HERE!!
Old 03-26-2009, 04:56 PM
  #346
Trolling Canuckistan
black label's Avatar
Most of the info here is on the single flex pipe design. If the headers you are looking at have 2 flex pipes then they are the 2nd and less trusted design.
Old 03-26-2009, 07:45 PM
  #347
B A N N E D
StonedCL's Avatar
When u say Flex pipe, do u mean the weave looking thing?
Can anyone post a pick of both so we can see which ones are better and which ones ont to buy?
Old 03-26-2009, 07:48 PM
  #348
B A N N E D
StonedCL's Avatar
http://cgi.ebay.com/ebaymotors/98-99...1%7C240%3A1318
Are these the new ones or old ones?
good or bad?
Old 03-26-2009, 08:33 PM
  #349
Quarantuning
good or bad?
Those are the new two flex pipe design. They are unproven as far as I know. From the looks of it they wiil not fit 6speeds because they don't seem to have the bend in the manifold.
Old 03-26-2009, 08:38 PM
  #350
GreenMonster's Avatar
good or bad?
Those are neither... They aren't the XS power (or SSautochrome) that we've been discussing here in this thread. The XS power header have a single flex connection...
But I remember someone who bought the one in the ebay auction complaining about the dual flex headers... so I think those are bad...
You can't get XS power header at this time:
https://acurazine.com/forums/2g-cl-2001-2003-50/xs-header-update-email-715670/
Old 03-26-2009, 08:56 PM
  #351
B A N N E D
StonedCL's Avatar
https://acurazine.com/forums/showthread.php?t=715670
So none of those headers on ebay that people are selling for 80-120$$
are the ones we talked about?
No one on ebay is selling those, I could have sworn I seen a thread that those were the same thing???
All those headers on EBAY or worste then the xs?
Old 03-26-2009, 08:57 PM
  #352
B A N N E D
StonedCL's Avatar
http://motors.shop.ebay.com/_Car-Tru...L+2001+headers
None of thes are xs headers?
Old 03-27-2009, 03:32 PM
  #353
sinfulj32's Avatar
^xs headers are not being produced at this time. what everyone is trying to say is, dont get the ebay ones you see
Old 03-27-2009, 10:38 PM
  #354
Yes, it's the weave looking thing. If you can find a set, they will only have the flex pipe near catalytic converter connection. The pics you link to have the second, engine side flex pipe as well.
If you read this thread front to back you will see that some folks had issues with their flex pipe potentially causing excessive resonance. Some folks (myself included) have used exhaust wrap to avoid or resolve this issue. That said, I wouldn't want to add another flex pipe into the equation.
My advice is to throw up a WTB thread in the BM and see if some one had a set in the garage that they never got around to installing. Either that or wait for a part out of one of the seemingly endless supply of participants from the great 2nd gen CL demolition derby of 2009.
Old 03-27-2009, 10:56 PM
  #355
Your Garage
DC3328's Avatar
seriously if i see a CL on the road im gonna start driving in the opposite direction
Old 03-28-2009, 08:01 AM
  #356
B A N N E D
StonedCL's Avatar
So the XS will have the flex pipe (weave look) by the catalytic converter, but will not have the smaller flex pipe (weave ) by the front header connection!
Old 03-28-2009, 10:48 AM
  #357
eggs act lee
Old 04-08-2009, 08:53 PM
  #358
RendanCLS's Avatar
Should I buy these?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Old 04-08-2009, 09:32 PM
  #359
Ravi621's Avatar
Originally Posted by RendanCLS
the Y pipe is missing or not listed in the auction. it only comes with the 3 to 1 headers. those headers connect to another pipe to go to the cat like in the pic below.
Old 04-08-2009, 09:37 PM
  #360
RendanCLS's Avatar
Ok, I don't have the other pipe for them so probably not a good idea to buy them huh?
Quick Reply: *** XS Power Header Owner Thread ***
