$90 Wood Grained steering wheel upgrade
So I needed a new steering wheel...I searched around the forum and from the info I read it seemed like the steering wheel was interchangeable with the 01-02 Acura MDX. I purchased the steering wheel from Ebay member "magautoparts" for $90 shipped...took me about 30-40 minutes to install and I couldn't be happier. As you can see from the pics it looks like it's just a shade darker but it don't bother me...the camera flash makes it more noticeable than it really is.
It appears as though the OP has an 03 6MT, so yes.
yea at first i wished I had the silver interior but honestly all i get is compliments on the black marble interior finish. and the wheel is just a bonus.
too bad there isn't a brushed aluminum one for the CL6ers
It appears as though the OP has an 03 6MT, so yes.[/QUOTE]
Thanks...yes, the steering wheel is on a 2003 Acura CL with a 6 speed...the wheel is designed for a 01-02 Acura MDX but they are interchangeable with the CL
It wasn't that hard to install...took me about 30-40 minutes and all you need is the following...screwdriver, 14mm socket and a T30 tork bit. There was no need for a steering wheel puller...
Thanks for the info but I ran into a problem with mine. . .the screws that attach the "steering dynamic damper" (rubber thing on top of middle part of steering wheel after srs is removed) did not fit the mdx steering wheel. Did you have that problem?? if so did you use different screws or just leave it off?
me too. ive yet to see marble finish in any other car i really like it.
Thanks again. I thought those were just extras for the steering column but they worked on the damper to i guess. I have an automatic and it really goes well with my mdx wood grain shift knob.
rockyboy
08-04-2024 10:35 AM
