is $127 for 22.5K service BS?
Old Sep 6, 2002 | 09:37 AM
digitalgm's Avatar
"v1 saved my ass ......."
Well, is it?
AdamR
Old Sep 6, 2002 | 09:48 AM
ThoroDredCLS's Avatar
Shift_3.5 Auto
Re: is $127 for 22.5K service BS?
Originally posted by digitalgm
Well, is it?
AdamR
What service are you getting at 22,500. There should only be 15k then 30k. Anything in between that should be checking your fluids and topping them off or manual check on ac filter. Unless you are getting alignment done or tire rotation done. IF i am missing something let me know. I just hit 22k on my speedo.
Old Sep 6, 2002 | 09:53 AM
digitalgm's Avatar
Re: Re: is $127 for 22.5K service BS?
Wierd, my service light came on and I took it to the dealer and they said it needed the 22.5K service. .... damn its so pavlovian with that freaking service light ..... hmmmm though :P
AdamR
Old Sep 6, 2002 | 10:00 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
They riped your azz digitalgm... The 15k should run you some $100... the 22.5k is just an oil change, tires rotation, and fuild checks....!!! maybe $29.99 at the max
Get a detailed invoice and list of work done and bitch about it!!!
Old Sep 6, 2002 | 10:02 AM
digitalgm's Avatar
I do have a detailed invoice - its like parts 30$ and labor over 90$... wtf is up with that? I mean they fixed my sunroof and resurfaced my rotors but that is just shit that is broken because of them not me!
AdamR
Originally posted by Nashua_Night_Hawk
The riped your azz digitalgm... The 15k should run you some $100... the 22.5k is just an oile change, tires rotation, and fuild checks....!!! may $29.99 at the max
Old Sep 6, 2002 | 10:04 AM
Shift_3.5 Auto
AdamR
Ok, better question! What dealer told you that B.S. Are you in MD???
Old Sep 6, 2002 | 10:05 AM
digitalgm's Avatar
Pohanka in Chantilly VA off of 50.
AdamR
Old Sep 6, 2002 | 10:09 AM
Happy CL-S Pilot
man... that sucks all what you paid for should be done under TSB (warrenty) for FREE.. the rotor are covered so is the moonroof...
Get back your moeny man... that suck ass...
CO-CL-S's Avatar
AdamR
You could try reading the manual that came with the car. It tells you what needs/should be done for the different service intervals. You would then decide if it was worth it or not, or going to Acura or your local shop and having the work/checks done. As above, rotor resurface is under TSB 01-017 (I think that 's the number)..YMMV
Old Sep 6, 2002 | 10:17 AM
Shift_3.5 Auto
AdamR
Tire rotation at most should only cost between 15 and 20 bucks. If they are charging you way more for that, then you need to find an independent shop. Try calling Radley Acura they seem to be okay with prices and service.
Old Sep 6, 2002 | 10:20 AM
digitalgm's Avatar
Well I am on the phone with them right now bitching!
AdamR
Old Sep 6, 2002 | 10:24 AM
Shift_3.5 Auto
AdamR
Do yourself a favor and turn the car key II while in the ignition, hold down reset and trip I think for 10-20 secs and the light should go off.
Old Sep 6, 2002 | 11:44 AM
GoldenChild's Avatar
I'm a reader not a writer
at 22,500 the dealership wanted to perform the service but I told them No, to just do the Oil Change and the Rotation ($45) same service without the price tag (they are supposed to check the fluids and inspection normally)
One thing to look out for is when they do the rotation and rebalancing make sure they do all the wheels. My dealership only did the ones in the front. They gave an excuse why the other two were not done.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
