will +45 offset rims be ok for my 06 TSX??
Hey folks....
i just picked up a used 2006 stock TSX over the summer
I've determined the wheel specs are:
215 50 R17
Bolt pattern 5x114.3
Centre bore 64.1
Hardware 12x1.50 LUG
Offset 55
I was looking on tire rack and saw Zinik Z30 rims that Tirerack says will fit.
The rim specs are:
Offset: +45mm Backspacing: 6.06" Bolt Pattern: 5-114
Rec. Tire Size:215/50-17
Weight: 23.6lbs.
I'm concerned about the offset. Can anyone provide advice/experience? Will the difference in offset matter?
Once this winter is over, I plan to put my winter tires on the stock rims, and put my stock tires on the Zinik rims.
Has anyone had any good/bad experience with Zinik rims?
thanks all,
215 50 R17
Centre bore 64.1
Offset 55
The rim specs are:
Weight: 23.6lbs.
thanks all,
imzimz (12-06-2011)
Yup. Four of us just returned from a ski trip to Montreal, and all our stuff. I've been using a 16 x 7 with +42 offset for my 205/60-16 snow tires, for several years, without problem.
Thoughts/questions about 45 offset
I am also planning on going from stock 55 offset to Acura accessory rims with a 45 offset. Will this yield any noticeable improvement in handling if I keep the same size tires (def wouldn't want to go narrower)? Might be a stupid question but I'm thinking the slightly wider stance might help a bit. Also, should I be concerned about more mud, road grime hitting the side of car? TIA!
Yes they'll fit but damn those wheels are hideous. Wheels like that only belong on Buick's and Lincoln town cars lol. Enjoy them. Some wheels just don't belong on Japanese/European branded cars. But just my .02...
mlody
12-04-2019 02:11 PM
SinCityTLX
55
10-11-2015 01:20 AM
