Tanabe Sustec PRO S-OC Type II Coilover for TSX
Hi,
Are there anybody here who has experience with Tanebe Sustec PRO S-OC Type-II coilovers? It's new for TSX and I think it serves comfort and performance with a reasonable balance which is good for us who drives on rough roads. Price is reasonable, is about $650-$700...
Do you know anywhere which can take orders from Europe?
SUSTEC PRO S-0C Type II features all of the benefits of the S-0C in a lower cost, high value package. The Type II is a non-helper spring model that features a longer main coil spring.
Dispelling a popular belief that a firm or harsh ride is a sign of a performance suspension, the short stroke, shortened case dampener of the S-0C Type II is extremely unique in that it’s internal construction allows it to deliver superior handling without sacrificing strength or ride comfort.
Unique double-cylinder design allows for full suspension stroke within the shortened shock body while Low-pressure gasses ensure smooth rebound characteristics for additional ride comfort.
For all driving enthusiasts.
I think Bender has them on his car. He has indicated that they are very comfortable. I think their spring rates are something like 8K F and 5K R which are softer than Tein's 10K/6K for their Basics and SS or 14K/8K for their Flex.
I would definitely consider them for a street car. If you plan to autocross or take your car to the track, the Tein Flex is probably a better choice.
Here's the application list showing the TSX and the spring rates of 8K F and 4K R as compared to Tein's significantly stiffer rates of 10K/6K and 14K/8K :
http://www.tanabe-usa.com/coilovers/...tions.asp?id=8
As for where you can buy these coilovers. If you want to check them out locally, I saw some at the Super Autobacs in Stanton, CA.
Another question...
Are all coilover with different brands adjusted from the top of the suspension?
For example Tein can be adjusted from the dial under the hood for fronts, and under the seat for rears.
Is it same for the Tanebe?
I think that Tanabe model does not have dampening adjustment.
I'm seriously looking into buying a set of these. Do a search on the clubrsx, and there are tons of people with this system and surprisingly not a single complaint!
I got to ride in a DC5 with a set of these on and it was reaaaal nice. Felt soft and comfortable, but handled exceptionally well. I think these would be great for the street. Those other rates for the other coilovers seem wayyy too high for the street.
They say, the rougher the road, the softer the spring you need. If its too stiff, the car will just bounce around. According to their website, you can order custom spring rates.
http://www.tanabe-usa.com/coilovers/s-oc.asp
Competition Spec PRO210 Race Spring
Features the same highly tuned spring rates as our high performance S-S model. PRO210 was developed for extreme durability and balance. This spring has the highest tensile strength available due to our patented manufacturing process. For professional suspension tuners, custom rates and sizes are available.
I'm with you on this one loxllxol. Hopefully by the end of summer, I'll be able to pick up a set of these too. Haven't really found any vendors that have them for the TSX yet though. Too new of an application maybe?
Yes you are right johnny...
It's a new application for TSX.
I have to find a dealer which is able to send overseas.
modacar.com sells Tanabe which accepts international orders.
I e-mailed them, no reply came yet.
I will order comptech strut bar and Injen CAI/SRI (have not decided wich one yet) together with Tanabe's actually...
I read the description on Tanabe's site about the S-OC and S-OC Type 2, but I still don't know what the difference between the 2 are except that the S-OC is about $300 more than the S-OC Type 2. So anyone know?
street price is always much lower then retail
I think the only difference between the two models is that the type ii does not have the helper spring, which i think is for comfort only. I doubt that tiny spring does much to hold the car up, so you probably can't tell the difference.
I would just get the less expensive Type II's and get a pretty sweet setup for
How about emailing Tanabe or just giving them a call to find out who'll ship it? I've never ordered anything from modacar before, so i dunno how reputable they are.
USA is a long way to travel if modacar messes up your order
When the helper springs are so light, they cannot really affect ride quality as they will completely compress when the car sits on its 4 wheels and tires. The purpose of those springs is to keep the spring in place when the suspension is fully extended. For instance, if you happen to catch some air and the 4 tires actually leave the ground. In some instances, if the spring is too short, the spring can actually dislodge from the spring seat. The helper spring prevents this from happening by always maintaining a certain amt of pre-load on the springs even when the suspension is fully extended.
dang it, i was 90% sure on getting the h&R coilolvers, but now i'm getting these specs for the tanabe's vs. the h&r ( f8k r4k vs. f10k r8k) and starting to doubt what to get. sounds like tanabe is a softer ride.
You can't really go wrong with either one. I'd say between Tein Basics, Tanabe Coilovers, and H&R...I'd just go with the cheapest price.
Originally Posted by AlterZgo
Where were you able to find the specs for the H&R coilovers?
Have you priced out the H&Rs? Aren't they in the $1200 neighborhood? If so, seems like the Tein SS or Flex would be a much better deal b/c they are both adjustable and the Flex comes w/ upper pillow-ball mts and has independent preload adjustability.
Hopup Racing sells Tanabe Sustec S-OC Type II for $719.
Any experience with this place?
I'm thinking to order some other stuff for my Euro Accord from here....
http://www.hopupracing.com/suspension19.html
Bye TSX, hello domestic?
wasn't able to get them from the u.s. reps, but i got it from a reputable source who was able to get the specs from h&r rep in australia. maybe those coilover specs aren't for our tsx's, but i assume the u.s. specs aren't that far off from our down under counterparts.
Because of the difficulty in rating progressive springs, even having a number doesn't always tell the true story of how the spring feels. However, I do believe that these H&Rs are designed to maintain a reasonable ride quality, and they will probably will perform that way. No one can say for sure though, because I don't believe anyone has them yet.
I decided to roll the dice on the US Spec Tein Flex with it's 14K/8K rates, based primarily on a discussion with a Tein rep, who swore to me that these coilovers are designed with ride comfort as a primary feature, and this somehow has proven to be true.
Looks like we need a guinea pig for the H&Rs .......
Looking at the numbers for the Tanabes, it certainly seems as it will be soft. My only concern would be can those rates keep the struts from bottoming out over large bumps, especially if you lower it down a lot.......the more you lower the Tanabes. the less travel you'll have.
Drives With Hands
I think the application is extremely new so not many people have used it yet.
The Tanabes are probably the most comfortable on the market judging from the spring rates, and i doubt they would underdampen their coilover to allow it to bottom out. That 14/8 rate seems a bit off for the TSX, those kind of rates are for a car that is very front heavy, with a massive engine. I think only Supras and GS430s run those kind of rates, but even then those are running rates like 14/10, 14/12
I found some posts by bender, and his comments were that they were very comfortable. "Bender"
From www.tanabe-usa.com
Anyone planning on getting these very soon?
Rep'n Taxbrain.com
Originally Posted by CJams
has bender made any posts about these? I looked for him, but I haven't been able to locate his screen name....is it just bender?
Yes, Sir... What can I help you guys there? If anyone still need answer.
My TSX still equipped with Tanabe Sustec Pro S-OC TypeII.
It give a very soft comfortable ride quality. I got Eibach ProKit before. Stiff for Me.
Tanabe Coilover is a little bit stiffer from OEM. Better handling.
I will rated - OEM > Tanabe Coilover > Eibach Prokit
It is only Height Adjustable. Great for Daily Drive, Definitely NOT for Track/Performance.
Bender
Bender
Originally Posted by rmpage
So you would say these coilovers are good for lowering to get aesthetic looks, but inferior for performance handling?
That's dissapointing... I was hoping these Tanabe's would offer some good performance advantages. Maybe i'm better off grabbing some tein basics for performance?
I just got a quote (in Australian dollars) of 1810 for Tanabe Sustec Pro S-OC
+ a whiteline sway bar. I'm really considering getting this as it works out about 1600 Ausy dollars for the coilovers. What do u recon guys should i go for it? Or weight untill Tein Basics are available?
Master Graphic Artist
Bender
Bender
Bender
Bender
Originally Posted by DjElucid
just curious how much better than OEM handling? Woud it be closer to the prokit or more to OEM? Do you have any pictures? How low have you lowered it?
Oh, Man
I posted this picture like 10 X before already...
Maxium Drop with 18"... It scratched inner fender !!!
Bender
