Replacing only front tires?
hello everyone,
I recently bought a tsx (been 3 months) and the acura service guy now tells me the front tires are pretty much gone. I haven't taken the car to any other place to check but has anyone replaced only the front tires? If I do have to replace only the front tires (which seems very likely when I looked at the tires
), can I put on tires of a different brand or do I have to stick to the same brand as the rear ones? Btw, is there a way to check the condition of the tires myself?
appreciate all the help folks!
Generally replacing tires in pairs is OK. Your more worn tires should go on the back axle and your newer tires on the front. Its OK to have different brands of tires as well (if you don't mind the different look on each axle). There are a number of tires that are considered better and are less expensive which a short search through this section will reveal.
It's not so much condition as tread depth. There's gauges you can buy cheaply enough which will let you know how deep the tread is. Anything less than 3mm and you should replace as the depth is insufficient to remove standing water and slow you down as quickly normal tread depth would.
Check all the tyres, but as the fronts are the ones used for driving, steering, and braking (mainly) they're the most important ones to have full grip from, esp. this time of year.
Depending on what's currently on the rear, I'd suggest 220-320 wear index tyres. Anything higher and whilst they'll last longer (punctures omitting) the handling on greasy surfaces will be less than confidence inspiring once the tread has worn a few mm (7-8mm is normal depth when new).
http://www.etyres.co.uk/tyres-rating...ar-ratings.htm
There are so many negative comments about the OEM tires, so believe that putting anything else on one axle will give your car a split personnality, in handling/cornering. Get four new tires, and check your alignment.
Have camera, will travel
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
2006 DGP Sold 10/24/2012
I'd also recommend replacing all 4 tires with a better-performing tire. If you shop around you can probably find a complete set for nearly the same amount as 2 over-priced OEM Michelins.
And be careful when mounting a set of new tires on the front only. Depending on the tires and your suspension, you may end up with a nasty case of oversteer as your rear tires will likely have less grip than the fronts... not a good situation if you come into a corner too hot... you want the fronts to slide before the rears...
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Sorry folks..I should have been more specific. Yes - I bought it used
So the OEMs aren't *that* bad ;-)
So guess I should replace all 4 instead of just the front 2. I was a little hesitant to be replacing only the fronts although I didn't want to spend double the money right now either![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
So I was looking at some (cheaper) tires and I found these on tirerack:
http://www.tirerack.com/tires/tires....cleSearch=true
http://www.tirerack.com/tires/tires....peed_rating=YR
These look to be decent tires considering price/reviews. Does anyone have any experience with either these? Anyone prefer one over the other? Suggestions for some other brand?
Thanks again everyone! Certainly helps to have folks like you around
Wrong size - 225/45x17
I wouldn't worry about only going for the two fronts - there is NO necessity to change all 4 at once to the same brand/model these days.
Depending on tread depth on the rears, you may find it worth changing them when it's time to rotate fronts to rear.
Stock tyres are alright - nothing to write home about, but not dire.
Personally, I'd recommend Toyo T1-Rs, Goodyear F1 GSD3, Yoko ES100, Avon ZZ3 (Mastercraft Avenger ZHP).
In fact, given the last one's price here, I'd be almost inclined to say sod it, get four new ones after all.
What, me worry?
Originally Posted by Santa Rosa Steve
And be careful when mounting a set of new tires on the front only. Depending on the tires and your suspension, you may end up with a nasty case of oversteer as your rear tires will likely have less grip than the fronts... not a good situation if you come into a corner too hot... you want the fronts to slide before the rears...![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Very dangerous to have "best" tires on front....
"Where do I install new tires if I only buy two?
If you're replacing only two tires, be sure to have them installed on your vehicle's rear axle. New tires will provide better grip than your half-worn tires and when they are installed on the rear that helps reduce the potential for your vehicle to fishtail or hydroplane in wet conditions."
From Michelin. Video if you are an unbeliever:
http://www.michelinman.com/care/tip6.html
Meh.......no mention of what drive those cars are - FW or RW.
Also, what the heck was the RWD BMW doing there?
As for losing a FWD car with the rear stepping out - where was the power on with opposite lock?
Best way to correct oversteer unlike quick lift off on RWD to bring it back.
And what mm tread was there on those tyres? If anyone is running less than 3mm, then they need educated - after a good hard slapping.
Funny how the white one doesn't understeer wide with the same tyres reversed - which it should if they are aquaplaning.
Too many unknowns or unqualifieds to be scientific proof.
Doesn't Rice His Car
1 Post
Originally Posted by DGH
Ditto.
Wow. Thanks for the info. I'll remember that in the future. Although in a blowout situation, you'd want your rears to go first, but if there's a likelyhood of that (due to wear), then the tire(s) should have been replaced in the first place.
What, me worry?
Remember that the people who made that video also make our OEM tires.
Michelin had no say in the performance of these tires.
Also remember that they made EXACTLY what Acura requested. If Acura had wanted a performance tire (and was willing to take the hit on comfort and treadlife) Michelin could have given them that too.
cammy5
09-04-2015 11:26 PM
asahrts
09-04-2015 05:55 PM
nuldabz
09-03-2015 05:49 PM
