Replace OEM Tires
Old Jan 1, 2005 | 02:53 PM
indydriver's Avatar
Replace OEM Tires
I have an opportunity to replace the stock OEM tires within the first 500 miles. I do not want to sacrifice any handling capabilities but the reality of my situation is that I will put a lot of highway miles on and need all-season. I want only OEM size. Just checking TR, it looks like the Turanza LS-V is a good option. Comments on this tire or any others that might fit my needs? What is the general opinion of the OEM Michelins?
Old Jan 1, 2005 | 04:16 PM
Dan Martin's Avatar
Photography Nerd
If you browse through this forum you'll see that the stock michelins don't have a good reputation. This thread is a good place to start: https://acurazine.com/forums/showthread.php?t=19051
Old Jan 2, 2005 | 10:04 AM
kurt_bradley's Avatar
Here's the I put in on that thread...
Here's a thread that's been going on recently about the Avid V4S that's been discussed recently
Here's my recommendation on 2 different Yokos:
I've used these on my car:
tire rack review of the Yoko Avid V4S
tire rack review of the Yoko ES100
Read the reviews. I'd take either one all over again.
I currently have the V4S.
If you go with the V4S: use the 215/50/17 93V
If you go with the ES100: go with 225/45/17 93W
Old Jan 5, 2005 | 04:45 PM
dowzer's Avatar
I'd recommend the Turanza LS-V. It's a great all around tire with a high treadwear rating without sacrificing performance/comfort.
Old Jan 11, 2005 | 08:31 PM
MrChad's Avatar
I kAnt Spel guD
I had V rated Turanzas on my Accord, man I hated those things they howled like non-other. They wouldn't stick worth crap, I'd seriously switch to a different choice, I fail to see how the stock pilots are worse then the Turanzas.
Old Jan 11, 2005 | 11:56 PM
VeniceBeachTSX's Avatar
Tuxedo Cat
Which Turanza? The EL42 which are delivered as OEM tires on a lot of cars are not very good, while the LS series has a great repuation for being quiet, smooth and long-lasting. I've used them on a previous car and thought they were very good, far better than our OEM Michelins. That said, it is not a performance tire and isn't designed to be "sticky" in high performance situations. Read the reviews on Tire Rack. Different tires altogether, just as there are many different flavors of Potenzas, of varying quality.
Very few OEM tires are particularly good for anything other than achieving the best possible fuel efficiency/emissions testing results.
rseb4agze
May 3, 2016 07:41 AM
lland
Oct 4, 2015 04:47 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
cammy5
Sep 4, 2015 11:26 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
