Progress RSB owners........Question...
B A N N E D
This is for people who have the progress RSB. Do you have it on the softest setting, or the more firm setting?
Planning on installing mine this wknd and want some opinions on how the car drives on either setting.
B A N N E D
Originally Posted by tsxman04
Firm setting. Noticeable improvement in handling. Have not personally encountered any detrimental characteristics since installing even during spirited driving.
Originally Posted by 925tsx
do the rear wheels need to be off the ground to install the sway?
Former Sponsor
Originally Posted by Simba91102
It seems to me that I've read here of installs done without taking the wheels off, but I don't see how. I had trouble getting the new bar in even with the wheels off (I had to drop the exhaust system off the two muffler hangers on each side). I was a mechanic in the bad old days, but I still know my way around things mechanical (and I still have almost every hand tool known to man). I swapped out the OE end links for the MOOG replacements at the same time and so far so good. I took my time and it took me most of an afternoon from start to finish.
The wheels don't need to come off the car, but they certainly need to come off the ground...my opinion.
B A N N E D
wow that was the easiest install ever.
That RSB was well worth the money. Its a whole different feel now. I can actually drive like i did in my 2004.
im sooooooooooo happy..
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
So did you set it to firm?
Contrary to other peoples opinion, I enjoyed mine in the softest setting. I initially set mine to the firmist but it felt too stiff and unbalanced ( maybe because I only lowered my car with tein type h) But after I change the setting to softest, it felt more natural and predictable. Even the softest setting still gives significantly improved handling compare to stock. Just my toughts.
Originally Posted by Zyuan10
i generally find my TSX to feel the same as before the installation and I have it on the firmest (to confirm, the inner most hole). Am I not turning fast enough? xD
i installed it at Softest (im pretty sure i saw JTSO recommend doing so)
Felt a noticable difference right away, but after a couple weeks, i guess i got used to it and dont' notice it at all now.
i gotta go back under and install the Moog endlinks now, maybe i'll change it to firm at the same time.
Former Sponsor
Hate to admit it, but my experience has been the same. With Koni yellows set the lowest and 235/45x17's on 8" wheels, I wasn't sure what this install would do for me. I'm afraid it doesn't seem to have done too much. I'm fairly aggressive when and where possible, but the car doesn't feel a whole lot different. I'm not going to do something stupid just to try and find the limit (although I do subscibe to the theory that supposes "you don't know how fast you can go until you know how fast you can't go".
Hmmm, that might not be the greatest idea. Why not try reinstalling the stock one? I have found that mods tend to be more noticeable when you remove them than when you install them.
I also did the end link change; they're quite cheap (in a mod sense), and they do look so much beefier (the MOOG replacements really are a nice piece of work; the grease fittings are icing on the cake. Too bad they're so hidden). That said, I kind of agree with what you expressed elsewhere on this thread concerning replacement. The two OE links I replaced were still almost like new (aside from the rusty studs which made removal an exercise in time and patience), and this after 60K miles and 2 New England winters. After I had them out and cleaned up, I started to wonder what this was all in aide of. I'll leave this setup on the 05 until it's time to get rid of the car and then I'll just move everything over to the 07. I'm planning on doing an A-spec suspension upgrade at the same time, so I think I'll get my moneys' worth of the bar and link upgrade.
sorry, if it wasn't you jtso. i read a bunch of threads on the RSBs and there were a couple discussing which one was better and a couple threads with supposed problems related to the RSBs. I guess it was someone else who said that.
when i said i was going to install the moog endlinks, i didn't mean that i was doing it as a performance mod or anything, it was more of a re-assurance mod. I only mentioned it since i was going to install it at the same time i was going to try the hard setting on the RSB.
back to the topic, it seems the RSB on the stock suspension can only do so much, lower the car seems like it would help so much more (and perhaps put less stress on the RSB which means less stress on the endlinks and mounts). i've been lookin at the tokicos w/ some tiens...
i still like the RSB and for the $135 i paid (actually my gf bought it as a gift), i still think its well worth the money.
Former Sponsor
I understand the "reassurance" metality, but reassurance against what? That is what I am wondering. It seems like it is a modification done for the sake of making another modification. I am wondering if there are problems with the stock links at all.
In actuality, but lowering the car and upgrading the suspension you are enabling the the sway bar to do less work. As the stock shocks and springs are soft with long travel, the sway bar is doing the most work on a stock suspension. Lowering the car does move the sway bar's geometry, but as long as the links are not forced out of their range of travel there is no more or less stress on them.
Yes, the RSB by all accounts is a great bang for the buck! This cost/benefit ratio is a little less favorable when people start getting bushings and links they don't need though, and it just causes me to ask "why?"
Marcus
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
