Help with RIM SPECS such as (OFFSET)
Hey guys i'm thinking of purchasing some aftermarket rims for my Tsx and well i have to admit i'm a newbie at this stuff.. and well the specs to the rims throw me off? Could someone help me understand what they mean here are some examples: Offset and Centerbore what are they?
Center bore is 64.1mm
Offset is how far the the wheel mounts off the center of the rim. So, 55mm positive offset is 55mm out from the exact center of the wheel. Look at these examples, let's say the first example is 0 offest, the mounting point ("I") is in the middle of the wheel [ I ]
This second picture shows a positive offset wheel (like the TSX) [ I], the mounting point ("I") is moved 55mm towards the outside of the wheel. Get it?
Center bore is just that, how big the hole in the center of the wheel is made. Honda's have a lip on the hub the stock wheels rest on/around. It's size is 64.1mm in diameter.
I appreciate the infor bro it does make more sense to me but for some reason i can't view your examples is there any way to send em to me? I'm pretty sure those will help me even better understand again thanks alot bra.
Wheel Offset
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
