Please Help With WHeel Specifications
Alright guys, so I purchased a set of brand new ADR M-sports from a guy for $625. I really don't know much about wheels besides the 19 inch by 8.5 inch specs, but there is a 35 mm offset and other specs of 5 x 114.3, i dont really understand this, could anyone please help???
Littering and.....
You should use the search feature on this forum before starting new threads. Typing in 19x8.5 would have lead you to this thread:
https://acurazine.com/forums/showthr...ghlight=19x8.5
Read through the thread, there are two members running 19x8.5s and one of them has the rims you purchased but with a different offset.
I think they might
I checked with the guy who is selling them and he said they should fit. A person has already had these wheels fitted onto an Acura TSX already, you can find it at the wheel gallery. Im pretty sure it should be fine
Photography Nerd
The wheels are going to stick out past the fenders so you're going to have to live with some rubbing.
Ackman did 18x8.5 with a 35mm offset and his wheels stick out: https://acurazine.com/forums/showthread.php?t=16317
Don't forget that the stock wheels are 215/50/17 with a 55 offset so you're making a major change. The wheel you've chosen sticks out 1.2" farther than stock.
Oh
The guy said with stock suspension, the Rims should work...
I don't think it's a question of looks now but its a question of whether or not my tires will rub. Personally, I dont think there should be a problem if i dont lower the car.
tell me what u guys think
Just dial 1911
1 Post
Photography Nerd
Personally I recommend you sell the wheels and buy something no wider than 8" and with a +42 or higher offset.
Just dial 1911
1 Post
Alright
Thanks for your input guys...I understand that 35 mm offset would be a little unorthodox for my car...well I was aiming to get the car to look like this one:
http://gallery.bussert.dyndns.org:81...tsx_05a?full=1
now I have to find those exact same rims with a 40 mm offset, any one have any ideas or hookups as to where i can get them???
Please post
Please post
ATCer
Please post
Please post
You might start with the shop that you ordered/ were going to order the original set from.
Alright
Alright guys, so I'm now going to look for the 19 x 8.5 rims...with a 40 mm offset.
THese rims should work and fit on my tsx...
tell me if you think otherwise
Why will the driveability suffer? WHat should I do to not let this happen?
If you don't want tramlining, go with a narrower tire. If you don't want the ride quality reduction, go with a larger profile tire.
Bye TSX, hello domestic?
i'm not trying to be a doomsayer, just explaining some of the negatives of improper fitment. I have 18x7.5 +42 wheels and they fit very well, but even on a 225 width tire and reasonable (ie 40 or greater) offset there is some pull. a 19x8 +48 would probably be optimal, but you'll be ok w/ 19x8.5 +40, just not as smooth. I'd say its impossible to get a 19x8.5 +48 however, so you'd have to comprimise somewhere.
THanks for your input guys.
DO you think maybe i should go with 8.5 in the rear wheels and just 8 in the front? would that make a difference?
Got Milk???
Originally Posted by CGTSX2004
Never on a front wheel drive car, especially if it came from the factory with all four wheels and tires the same size. If you go with a smaller wheel, go smaller on all four.
just curious, what happens to FWD if u go staggered fitment?
Originally Posted by xizor
like CG said you'll understeer, but that's if you a wider tire to go with the wider wheel in the rear. the wider tire in the rear will provide more traction than a skinnier one in the front, causing understeer. although if you used the same tires its possible there'd be no difference
