Nakayama Vador
I'm the Firestarter
Nakayama Vador
These wheels are available in different offsets and bolt patterns. Which one(s) will fit best on the TSX?
http://www.tiretrends.com/wheel_cata...1U&wheelID=142
Ideally I'd like to go with a 17" to save cost on wheels and tires but I'm not sure which one fits...
I'm the Firestarter
Originally posted by dabuda2004
dang, looks like the TL optional 18" wheels
both the 17 x 7 - 5x114.3 and 18 x 7.5 - 5x114.3 wheels will fit
What about the offset though? It seems like they come in 42 mm and 40 mm, aren't the stock 17x7 wheels 45 mm? With a smaller offset, will these wheels look too indented, or would they rub against the inside walls? The difference is only 3mm but still...
I should be able to take my OEM tires and put them on those wheels, right? (I know it's better to get real summer rubber but this might be easier to explain to the wife )
Photography Nerd
Stock is 55mm offset so these would stick out 13mm (1/2") farther than stock. Plus the wheel is another 1/2" wider so you would be sticking out 3/4" total. I think you might run into some rubbing issues here. Your OEM rubber would work fine.
Photography Nerd
Check out this thread for more fitment info: http://www.acura-tsx.com/forums/show...&threadid=1466
I'm the Firestarter
http://www.tirerack.com/wheels/tech/offset.htm
Registered AssHat
Originally posted by Belzebutt
Question: how would a smaller offset on the Nakayama make the wheel stick out more? According to Tire Rack, a smaller offset means they're more on the inside, no?
Also, I'm running an 18"x7.5" +48mm with 235mm tires and it looks near stock, with the front wheels being flush with the fender edge.
Actually, if you look at the illustration, the offset is the distance between the two mounting surfaces. Since the TSX comes stock with a 55mm offset, to go to a 45 mm offset means you lose 10mm of the distance between the mounting surfaces. This translates into more of the wheel being on the outer/front part of the setup, causing the wheel to stick out more. However, judging by the pictures that dabuda provided, the difference in offset doesn't affect the look too much.
BiggyMcWang
17
12-18-2008 07:45 PM
Type-S RPh
04-11-2006 07:42 AM
Belzebutt
08-18-2004 11:49 AM
SavoyPrime77
12-17-2003 06:14 AM
