Mods to fit 19x8.5 or 19x9?
What mods need to be done to fit a 19 x 8.5 or 19 x 9 wheel with a deeper lip with a lower offset? Roll fenders? Anything else? Are there long term side-effects that would result that I should be concerned about by trying to fit these wheel specs? I just want a wider wheel/tire and deeper lip than our standard 19 x 8.
Yohan
19 x 9.5 here. I would not recommend of using this setup since steering becomes really heavy, however you get a really sticky glue to the tarmac, and also you will require quite a high offset to produce that deep dish. I'd say 6 cm dish is possible without any fender rolling. But above that, it is not possible without modifications.
