Minimum Tire Load Rating for TSX?
9th Gear
Hi, I was wondering if it is safe to use 235/40/R18's with load index of 91 at the front and 225/40/R18's with load index of 88 at the back~ I know 88 is too low for TSX, but is it ok if only the rear tires have this? (Yes, 91 is ALSO low
) Thanks!
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
) Thanks!
Audi Driving Snob
Originally Posted by Dan Martin
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
and 91 load rating is fine.
You'll probably need to run a slightly higher tire pressue to keep handling and road feel similar in a 91v tire. Most tires have a lower load rating because they have a softer sidewall. Not coincidentally they are usually also lighter. The higher tire pressure stiffens up the sidewall to mae it more similar to the tires with higher load ratings.
Use all 3 Pedals at once
Stock=215/50/17 with a 93 Load Index
Aftermarket=235/40/18 with a 91 Load Index or a 95 Load Index
In what ways do the load indexes affect ride comfort and performance?
If I get a wheel with a lip, would you guys recommend getting a tire with the higher load index so that there is less sidewall flex and thus reducing the chances of bending the lip in a dip or pothole?
Bridgestone S-03: 89
Falken FK-451: 89
Toyo T1-S: 93
Toyo has the highest load rating of the three, but IMO it has the softest sidewall. The sidewall constructions of these tires are:
Bridgestone S-03: 2 plys
Falken FK-451: 2 plys
Toyo T1-S: 1 plys
(Just for comparison sake)
Falken Azenis RT-215 (215/45/16): 3 plys
Kumho Escta V710 (225/50/16, R-compound): 3 plys
The way I determine how soft or stiff the sidewall is is by having the same tire pressures in each tire and see how much rollover is at the auto-x. Toyo T1-S definitely had more rollover than all the others I've tried.
Originally Posted by Black Ninja
Is rollover a good thing?
I was either planning on going with the
Bridgestone Potenza RE750 235/40/18 91 Load Index
or
Yokohama ES100 235/40/18 95 Load Index
Which would you guys rather go with?
I want a tire that doesn't look under inflated even if it's at normal pressure.
or
cycdaniel
12-17-2019 10:58 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
nuldabz
09-03-2015 05:49 PM
