Kumho Ecsta ASX owners.... any flat spotting?
I've had them for a few weeks now, and noticed that every morning (or whenever the car sat for a few hours) when I start driving there is a constant vibration that feels like the tires are flatspotting.... this vibration tends to go away after a few minutes of driving....
Also, what psi do you set the tires at? Right now I just set them all to 32 psi, and for some reason whenever I take my car to the dealer or Sears for the balancing, they always set it to 35 psi....
Someone stole "My Garage"
I get the same thing on cooler nights/mornings w/ my Toyo Proxes TPT tires. I think its somewhat normal for a tire to get this when cold, and since it goes away within 1 or 2km, it shouldn't harm the tire at all.
Edit: 32 or 33psi.
Edit: 32 or 33psi.
From a guy I know who owns www.tiretrends.com:
This does happen when temperatures start to drop. Mostly with performance tires. This is because of the nylon cap that sits on top of the steel belts. The nylon cap is a layer placed over the steel belts that bonds the steel to the tread and holds everything together. This is especially important at higher speeds and during enthusiastic driving. This layer also protects the steel from impacts/punctures that may allow water/moisture to cause corrosion and eventual tire failure. So not only does this nylon cap help with performance, but it is a very important safety feature.
One draw back is that when temperatures start to drop it can cause the nylon cap to distort or "flat spot". This usually happens when the cars sits overnight. Once the tire heats up the problem usually disappears.
Bye TSX, hello domestic?
only wheels i've had this w/ was my previous kumho 712's, maybe the brand is worse than others at flattening overnight, but its normal so don't sweat it
I think the reason you wouldn't feel it on some tires but would on others, is because of the softness of the rubber.
OEM tires are hard as hockey pucks eh.
Toyo T1-S are REALLY soft (ZR rated).
Originally Posted by supraken
True that... I like the Kumho's so far, has been pretty good in dry and wet.... we'll see how they do in the snow
how is road noise compared to the stock tires when you bought them?
I'm considering these for my next set.
Got Milk???
I'm running these tires, on occasion I feel the "slight" vibration after a pretty cold night, but it's not like it's shaking your ass off or anything. You'd have to be really feeling it. After a few minutes of driving, it's gone, just need to warm up the tires a bit, not a problem at all.
KC
KC
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
